• gallery
  • gallery
  • gallery
  • gallery
  • gallery
  • gallery
{{cart.select_candidate_product.title}}
{{ promotion_link() }}{{ promotion_link() }}{{ money_or_status_text() }}
FREE SHIPPING
  • Ready-to-fly aerial system
  • Included professional 4K camera and 3-axis stabilization gimbal
  • Live, wireless HD video transmission via DJI Lightbridge
  • Dedicated remote with flight and camera controls
  • Powerful app to adjust camera settings, edit videos, and more
  • Vision Positioning system for GPS-free or indoor flight
  • Perfect for high-level shoots and professional sets
    More
    Recommended Accessories
    Aircraft
    Model
    T600
    Weight (Battery Included)
    2935 g
    Hovering Accuracy (GPS mode)
    Vertical: 0.5 m
    Horizontal: 2.5 m
    Max Angular Velocity
    Pitch: 300°/s
    Yaw: 150°/s
    Max Tilt Angle
    35°
    Max Ascent Speed
    5 m/s
    Max Descent Speed
    4 m/s
    Max Speed
    22 m/s (ATTI mode, no wind)
    Max Service Ceiling Above Sea Level
    4500 m (Default altitude limit: 120 m above takeoff point)​
    Max Wind Speed Resistance
    10 m/s
    Max Flight Time
    Approximately 18 minutes
    Motor Model
    DJI 3510H
    Propeller Model
    DJI 1345T
    Indoor Hovering
    Enabled by default
    Operating Temperature Range
    -10° to 40° C
    Diagonal Distance
    559 to 581 mm
    Dimensions
    438x451x301 mm
    Power Spectral Density
    9.06mW/MHz
    Gimbal
    Model
    ZENMUSE X3
    Operating Current
    Station: 750 mA
    Motion: 900 mA
    Angular Vibration Range
    ±0.03°
    Mounting
    Detachable
    Controllable Range
    Pitch: -90° to +30°
    Pan: ±320°
    Mechanical Range
    Pitch: -125° to +45°
    Pan: ±330°
    Max Controllable Speed
    Pitch: 120°/s
    Pan: 180°/s
    Camera
    Name
    X3
    Model
    FC350
    Total Pixels
    12.76M
    Effective Pixels
    12.4M
    Image Max Size
    4000x3000
    ISO Range
    100-3200 (video)
    100-1600 (photo)
    Electronic Shutter Speed
    8s - 1/8000s
    FOV (Field of View)
    94°
    CMOS
    Sony EXMOR 1/2.3”
    Lens
    20mm (35mm format equivalent)f/2.8 focus at ∞
    9 Elements in 9 groups
    Anti-distortion
    Still Photography Modes
    Single shoot
    Burst shooting: 3/5/7 frames
    Auto Exposure Bracketing (AEB): 3/5 bracketed frames at 0.7EV Bias
    Time-lapse
    Video Recording Modes
    UHD (4K): 4096x2160p24/25, 3840x2160p24/25/30
    FHD: 1920x1080p24/25/30/48/50/60
    HD: 1280x720p24/25/30/48/50/60
    Max Bitrate of Video Storage
    60 Mbps
    Supported File Formats
    FAT32/exFAT
    Photo: JPEG, DNG
    Video: MP4/MOV (MPEG-4 AVC/H.264)
    Supported SD Card Types
    Micro SD
    Max capacity: 64 GB. Class 10 or UHS-1 rating required.
    0° to 40° C
    Remote Controller
    Name
    C1
    Operating Frequency
    922.7~927.7 MHz (Japan Only)
    5.725~5.825 GHz
    2.400~2.483 GHz
    Maximum Transmitting Distance
    Up to 5 km or 3.1 miles (unobstructed, free of interference) when FCC compliant
    Up to 3.5 km or 2.1 miles (unobstructed, free of interference) when CE compliant
    EIRP
    10dBm@900m, 13dBm@5.8G, 20dBm@2.4G
    Video Output Port
    USB, mini-HDMI
    Power Supply
    Built-in battery
    Charging
    DJI charger
    Dual User Capability
    Host-and-Slave connection
    Mobile Device Holder
    Tablet or Phone
    Max Mobile Device Width
    170mm
    Output Power
    9 W
    -10° to 40° C
    Storage Temperature Range
    Less than 3 months: -20° to 45° C
    More than 3 months: 22° to 28° C
    Charging Temperature Range
    0-40° C
    Battery
    6000 mAh LiPo 2S
    Charger
    Model
    A14-100P1A
    Voltage
    26.3 V
    Rated Power
    100 W
    Battery (Standard)
    Name
    Intelligent Flight Battery
    Model
    TB47
    Capacity
    4500 mAh
    Voltage
    22.2 V
    Battery Type
    LiPo 6S High voltage battery
    Energy
    99.9 Wh
    Net Weight
    570 g
    -10° to 40° C
    More than 3 months: 22° C to 28° C
    0° to 40° C
    Max Charging Power
    180 W
    Battery (Optional)
    Name
    Model
    TB48
    Capacity
    5700 mAh
    Voltage
    22.8 V
    Battery Type
    LiPo 6S
    Energy
    129.96 Wh
    Net Weight
    670 g
    -10° to 40° C
    Less than 3 months: -20 to 45° C
    0° to 40° C
    Max Charging Power
    180 W
    Vision Positioning
    Velocity Range
    Below 8 m/s (2 m above ground)
    Altitude Range
    5-500 cm
    Operating Environment
    Brightly lit (lux > 15) patterned surfaces
    Operating Range
    0-300 cm
    DJI GO App
    Mobile Device System Requirements
    iOS 8.0 or later, Android 4.1.2 or later
    Supported Mobile Devices
    * Compatible with iPhone 5s, iPhone 6, iPhone 6 Plus, iPad Air, iPad Air Wi-Fi + Cellular, iPad mini 2, iPad mini 2 Wi-Fi + Cellular, iPad Air 2, iPad Air 2 Wi-Fi + Cellular, iPad mini 3, and iPad mini 3 Wi-Fi + Cellular. This app is optimized for iPhone 5s, iPhone 6, and iPhone 6 Plus.
    * Compatible with Samsung tabs 705c, Samsung S6, Samsung S5, Samsung NOTE4, Samsung NOTE3, Google Nexus 9, Google Nexus 7 II, Ascend Mate7, Huawei P8 Max, Nubia Z7 mini,Sony Xperia Z3, MI 3, MI PAD, Smartisan T1.
    imovie
    Included in the Package (Single Remote Version)
    • Aircraft Body x1
    • Remote Controller x1
    • Camera with Gimbal x1
    • Propellers (Pair) x4
    • Intelligent Flight Battery (TB47) x1
    • Battery Charger x1
    • SD Card (16GB) x1
    • ND4 Filter x1
    • Manuals
    • Power Cable x1
    • Micro-USB Cables x2
    • Remote Controller Charging Cable x1
    • Harness x1
    • Camera with Gimbal Box x1
    • Carrying Case x1
    Are the two remote controllers the same? Should I setup the remote controllers in the app or somewhere else to control the camera and aircraft separately?
    The two remote controllers are physically identical. You can set the remote controllers to either "Master" or "Slave" through the DJI GO app if you wish to use dual controller mode.
    Can I upgrade and buy a second remote controller if I only buy a single remote controller now?
    Yes.
    How big is the Inspire 1?
    Its length x height x width dimensions without the propellers attached are 44 x 30 x 45cm (17.3 x 11.8 x 17.7in).
    What flight controller does the Inspire 1 use?
    The Inspire 1 uses its own new flight controller.
    Which motors and propellers does the Inspire 1 come with?
    The Inspire 1 uses 3510 motors and 1345 propellers.
    Does the Inspire 1 have a SD card included?
    The Inspire 1 comes with a 16GB micro-SD card. It supports SD cards up to 64GB.
    How can I put a GoPro camera on the Inspire 1?
    The Inspire 1 does not currently support GoPro attachments. The gimbal is designed to hold DJI cameras only.
    Is the camera's exposure automatic?
    The exposure can be set to Auto, for automatic changes, or Manual, if you wish to use a specific setting.
    How much weight can the Inspire 1 carry without its included camera?
    We do not recommend flying with any payload other than the included DJI gimbal and camera.
    Can I see the size of images through the app?
    Yes, you can preview image or video sizes through the DJI GO app.
    Do you have an LCD monitor available for the Inspire 1?
    No, DJI does not sell LCD or HD monitors for the Inspire 1. However, you can output the live streaming video to a compatible monitor or mobile device of your own.
    How long does it take to charge the battery? Does it comes with a charger?
    Yes, all Inspire 1 units come with standard TB47 charger.
    With the standard TB47 100W charger, it takes 85min to fully charge a 4500mAh battery.
    Can the mobile device holder be used on the Phantom 2 series remote controller?
    No, it cannot. The mobile device holder can only be used with the Inspire 1 remote.
    Where can I find info on the simulation application that plugs into the trainer port? Can you suggest a simulation program?
    There is no trainer port on the remote controller for the Inspire 1.
    When will ground station functionality be available?
    The Inspire 1 does not currently support ground station.
    More Faqs
