• gallery
  • gallery
  • gallery
Inspire 1 - 1360T Quick Release Propellers (For high-altitude operations)
Tax includedFree Shipping
Osmo Shield
{{ warranty.short_title }}
Including a pair of propellers, one clockwise replacement propeller and one counter-clockwise replacement propeller.
The 1360T Quick Release Propellers are designed to improve the performance of the Inspire 1 series at high-altitude locations.
A larger propeller pitch delivers greater propulsion to the aircraft at altitudes with thinner air.
These props should not be mixed with other models of propellers on the same aircraft.
Propeller Safety:
1. The gain values must be adjusted according to the combination of gimbal and motors used:
a. If the Zenmuse X3 or X5 gimbal and 3510 motors are used, no adjustments are necessary.
b. If the Zenmuse X5 gimbal and 3510H motors are used, no adjustments are necessary.
c. If the Zenmuse X3 gimbal and 3510H motors are used, adjustments are required. The recommended gain values are: Pitch = 90*, Roll = 90* and Yaw = 90*.
2. When flying at low-altitude locations, extra propulsion demand from the 1360T props will lead to reduced flight time and higher battery consumption, which in turn leads to an decrease in battery level.
*The recommended gain values are intended for flight at a low altitude location. Adjust the values according to the immediate environment at your discretion.
Diameter × Thread Pitch: 13 × 6 inch
