  • Genuine Power, 2600W High Output
    The battery capacity is 1024 Wh, supporting a continuous 2600W output until the battery runs out, [1] reliably running over 99% of everyday devices. [2] It can connect up to 5 expansion batteries [6][7], expanding to 11,264 Wh.
  • Multiple Charging Methods: Grid/Solar/Car Power
    Supports three charging methods: Grid power, solar power, and car power. Whether indoors or on the go, you can choose the best charging method that works for you. Solar charging is cost-efficient and clean [3]; or charge fully during a road trip [3] for convenient power use.
  • Leading the Way in Fast Charging, Fully Charged in 56 Minutes
    It's fast and easy to plug in, recharge, and go. In fast charging mode, it takes only 56 minutes to fully charge from zero, and just 37 minutes to go from zero to 80% [4]. Even if you start charging it right before heading out, it gives you the confidence to set off whenever you need.
  • Advanced Safety, Reliable and Durable
    Safety is a top priority for DJI Power 1000 V2. It boasts a long lifespan, retaining 80% capacity after 4000 cycles [8]. With one full charge cycle per day, it can serve for ten years [9].
  • Dual 140W USB-C Ports for Next-Gen Fast Charging
    DJI Power 1000 V2 features dual 140W USB-C output ports [10] delivering a combined 280 W, which is 40% more than typical dual 100W USB-C setups on the market. It easily meets the demands of most USB-C devices.
  • Extensive Accessories
    DJI Power 1000 V2 features two USB-A ports, two AC output ports, one SDC port, one SDC Lite port, and two 1/4" threaded ports. It supports connection to different models of solar panels, power supply cables, and adapter cables to meet diverse charging and expansion needs.
  • 26 dB—Sleep Undisturbed Indoors or Camping
    When charging, the DJI Power 1000 V2 operates as quietly as 26 dB [5] . Whether you're camping overnight or resting indoors, it runs quieter than the wind and no louder than a silent air conditioner.
  • DJI Drone Super Fast Charging
    When used with compatible accessories, DJI Power 1000 V2 enables SDC Super Fast Charging [3] for select DJI drone batteries [11], enabling takeoff in as little as half an hour. With three drone batteries, you can fly and film continuously throughout the day.
  • DJI Power 1000 V2
    DJI Power 1000 V2
  • DJI Power AC Power Cable
Upgraded 1024Wh Capacity for Easy Multi-Device Power Supply
DJI Power 2000
DJI Power 1000 V2
DJI Power 500
DJI Power 2000
DJI Power 1000 V2
DJI Power 500 Portable Power Station
DJI Power 2000
DJI Power 1000 V2
DJI Power 500
2048Wh Portable Power Station
1024Wh Portable Power Station
512Wh Portable Power Station
From 1 419 €
From 914 €
From 399 €
2048WhCapacity
1024 WhCapacity
512 WhCapacity
3000WMaximum Continuous Output
2600 WMaximum Continuous Output
1000 WMaximum Continuous Output
Approx. 22 kgWeight
Approx. 14.2 kgWeight
Approx. 7.3 kgWeight
4000 CyclesCycle Life
imgUSB-C Port Max Output Power
LFP (lithium ferrophosphate)Cell Chemistry
imgGrid Power
Car Power
Solar Power
imgGrid Power
Car Power
Solar Power
imgGrid Power
Car Power
Solar Power
USB-C Recharging
5000 mMax Operating Altitude
3000 mMax Operating Altitude
1. Under standard indoor conditions of 25° C (77° F), Power 1000 V2 can deliver a continuous output of 2600 W until fully discharged. Data was tested in a controlled laboratory environment.
2. Device power does not exceed 2600 W.
3. Requires certain accessories, which are sold separately.
4. Data tested under laboratory conditions at 25° C (77° F) and should be used for reference only. To achieve the maximum grid recharging power of 1440 W, the battery level must be at least 60%, and the ambient temperature should be between 20° C and 35° C (68° F and 95° F).
5. Measured at a distance of 100 cm from the Power 1000 V2 while charging in Standard Recharge Mode. For reference only.
6. DJI Power 1000 V2 can connect up to five expansion batteries, which provide up to 11,264 Wh when fully charged.
7. Sold separately.
8. Measured under 25° C (77° F) laboratory conditions using Standard Recharge Mode at 1000W output.
9. Based on the correct usage of the product, DJI Power 1000 V2 will have an approximate lifespan of 10 years, calculated on the basis of completing one full recharge/discharge cycle nearly every day. This data is for reference only. Actual user experience may vary.
10. The USB-C port supports a max output power of 140 W. The device being charged must support the PD 3.1 protocol and use a USB cable that meets EPR specifications.
11. For more details on fast-charge-supported DJI drones, refer to the "FAQ" page on the official website.
12. Data was tested in a controlled laboratory environment.
Notes of "Why Choose DJI Power?" section, for the United States, Canada, and European countries:
[1] The 2019 DJI Agras series introduced 9‑minute high‑power fast charging, a proven and reliable technology.
[2] Based on publicly available data as of 2025.
[3]All data are current as of 2025.
[4] Data from DJI Power 2000. Product performance may vary; refer to specific product specifications for details.
[5] *US CNN Best No.1 portable power station
https://www.cnn.com/cnn-underscored/reviews/best-product-launches-2025-07-04
*Yanko Design's Best of IFA 2025
https://www.yankodesign.com/2025/09/07/yanko-designs-best-of-ifa-2025-effortless-intelligence-and-design-driven-innovation/
*Certified by the Japan Disaster Prevention Safety Association; ranked No.1 disaster power supply by My Best.
[6] Based on 90th‑percentile transit times. Actual delivery times vary by region and logistics conditions; please consult customer service for specifics.
[7] Up to 5‑year warranty when purchased from the DJI Official Online Store.
[8] Return and exchange policy: https://www.dji.com/service/policy.
[9] Compatible with consumer products, some enterprise models (Matrice 400/350 RTK not supported) and handheld devices.
