Osmo Action FOV Boost Lens
When used with Action 5 Pro, it can expand the FOV to 182°. With the same shooting parameters, the FOV increases by 26% in width and 24% in height when compared to the standard lens without the FOV Boost Lens. While capturing selfies during surfing, the ultra-wide angle effortlessly includes your surfboard in the frame. When shooting from a first-person perspective, the footage is vibrant and immersive. Plus, the premium optical lens design ensures sharp and detailed image quality, capturing every thrilling moment of your adventure with precision.
1. The FOV Boost Lens is designed with convex optical glass. Please use it with care.
2. To use the FOV Boost Lens, the camera must be updated to the latest firmware, and FOV Boost Lens mode must be enabled.
3. Once the FOV Boost Lens is properly attached, the camera is waterproof up to 5 meters. However, using it underwater may cause image distortion, so it is recommended to avoid underwater use.
4. While 182° is the maximum optical FOV achievable with this design, the actual FOV during shooting may vary slightly due to distortion correction and stabilization settings.
Osmo Action FOV Boost Lens × 1
Osmo Action FOV Boost Lens Silicone Cover × 1
Dimensions: 38.6×38.6×17.43 mm (L×W×H)
Weight: 35.9 g
Operating Temperature: 0° to 45° C
Osmo Action 5 Pro
Osmo Action 4
