• gallery
  • gallery
  • gallery
  • gallery
  • gallery
  • gallery
Manfrotto - Gear Backpack Medium
Tax includedFree Shipping
Osmo Shield
{{ warranty.short_title }}
The Gear Backpack Medium is a compact, functional and ergonomically designed backpack that holds the Mavic Pro, the Osmo and its accessories. It can also accommodate DSLR cameras with large, fast zoom lenses (ex. 70-200mm f/2.8) attached. It can fit two additional lenses, for example a 16-35mm f/2.8 zoom lens and a 100mm macro lens.
Access is easy thanks to dual zippers that open fully to expose the contents of the backpack. Inside the front cover are organizer pockets for small items like media and business cards, cleaning cloths, phones, wallets, pens, cables and LED lights.
Both modular and easy to use, dividers allow you to custom fit the inside of your bag around your gear by creating the exact size compartment for you need.
A specially applied coating to the fabric makes it resistant to moisture.
The backpack comes with the option and proper connections to attach your tripod externally.
A fold-out protector which, when installed, creates a barrier between the wet outside and dry inside of your bag is included.
This bag fits the standard to be used as carry-on luggage. (Due to ever changing restrictions, check with your carrier prior to departure.)
Highlights
Waterproof and made to hold the Mavic Pro or Osmo and their accessories
Dividers allow you to customize the interior compartments to fit the gear you bring with you
Manfrotto - Gear Backpack Medium × 1
Internal Width(W): 12 cm
Internal Length(L): 25 cm
Internal Height(H): 33 cm
Weight: 1.045 kg
External Height(H): 35 cm
External Length(L): 28 cm
External Width(W): 19 cm
Color: Black
Material: Nylon
