• gallery
  • gallery
  • gallery
  • gallery
  • gallery
  • gallery
{{cart.select_candidate_product.title}}
{{ promotion_link() }}{{ promotion_link() }}{{ money_or_status_text() }}
FREE SHIPPING
  • Ready to fly, easy to control
  • See what your Phantom sees with live streaming video right on your mobile device
  • Capture photos and video with a single tap
  • The latest Phantom 2 Vision+ (v3.0) comes with the new remote controller, new propulsion system and new compass
Note: Click here for Phantom 3 Professional
    Features
    READY TO FLY
    Now you can shoot fully stabilized video from the sky, right out of the box.
    3-AXIS CAMERA STABILIZATION
    A built-in high precision 3-axis camera stabilization system brings a whole new level of smoothness to your aerials and gives you total creative freedom in the sky.
    PRECISION FLIGHT AND STABLE HOVERING
    The integrated GPS auto-pilot system offers position holding, altitude lock and stable hovering, giving you constant smooth flight so you can focus on getting the shots you want.
    GROUND STATION SUPPORT
    Program a flight path using your smartphone with our 16 waypoint Ground Station system. Tilt the camera up and down, take photos and shoot video all while the Phantom 2 Vision+ flies autonomously.
    ONSCREEN REAL-TIME FLIGHT PARAMETERS
    Keep track of current flight telemetry and see what your Phantom sees on your mobile device.
    HIGH PERFORMANCE CAMERA
    The Phantom 2 Vision+ carries an extremely high quality camera and a removable 4GB micro SD card. It shoots full HD video at 1080p/30fps and 720p/60fps, giving you crystal clear video and the option for slow motion shots. Photos are shot at 14 megapixels.
    CAMERA TILT CONTROL
    Tilt the camera as you fly, creating unique angles and amazing shots.
    SUPPORTS ADOBE DNG RAW
    DNG RAW photo capture means all original image information is retained for powerful post processing.
    ADOBE LENS PROFILE SUPPORT
    An Adobe lens profile for barrel distortion removal is available for the DJI Phantom 2 Vision+ camera.
    CAMERA PARAMETER SETTINGS
    Camera settings including Picture Quality, ISO, Exposure Compensation, White Balance, and capture Format can be adjusted through the VISION app.
    ALBUM SYNCHRONIZATION
    Beam photos and videos from the Vision+ straight to your phone using Wi-Fi. No computer required.
    Check out DJI’s brand new Phantom 3.
    Aircraft
    Supported Battery
    DJI 5200mAh LiPo Battery
    Weight (Battery & Propellers included)
    1242g
    Hover Accuracy (Ready to Fly)
    Vertical: 0.8m; Horizontal: 2.5m
    Max Yaw Angular Velocity
    200°/s
    Max Tiltable Angle
    35°
    Max Ascent / Descent Speed
    Ascent: 6m/s; Descent: 2m/s
    Max Flight Speed
    15m/s (Not Recommended)
    Diagonal motor-motor distance
    350mm
    Gimbal
    Working Current
    Static : 750mA; Dynamic : 900mA
    Control Accuracy
    ±0.03°
    Controllable Range
    Pitch : -90°-0°
    Maximum Angular Speed
    Pitch : 90°/s
    Camera
    Operating Environment Temperature
    0℃-40℃
    Sensor size
    1/2.3"
    Effective Pixels
    14 Megapixels
    Resolution
    4384×3288
    HD Recording
    1080p30 & 720p
    Recording FOV
    110° / 85°
    Remote Control
    Operating Frequency
    5.728 GHz-5.85 GHz
    Communication Distance (open area)
    CE Compliance: 400m; FCC Compliance: 800m
    Receiver Sensitivity (1%PER)
    -93dBm
    Transmitter Power
    CE Compliance: 25mW; FCC Compliance: 100mW
    Working Voltage
    120 mA@3.7V
    Built-in LiPo Battery Working Current/Capacity
    3.7V, 2000mAh
    Range Extender
    Operating Frequency
    2412-2462MHz
    500-700m
    Transmitter Power
    20dBm
    Power Consumption
    2W
    DJI VISION App
    System Requirement Of Mobile Device
    iOS version 6.1 or above/ Android system version 4.0 or above
    Mobile Device Support
    • iOS recommended: iPhone 4s, iPhone 5, iPhone 5s, iPhone 6, iPhone 6 Plus, iPod touch 5 (available but not recommended: iPad 3, iPad 4, iPad mini)
    • Android recommended: Samsung Galaxy S3, S4, Note 2, Note 3 or phones of similar configuration
    What's in the box
    Note: pictures are for reference only. Click to open expanded view.
    What are the differences between Phantom 2, Phantom 2 Vision and Phantom 2 Vision+
    The Phantom 2 Vision+ is our latest model, and our most complete package. It features a high quality camera, precise 3-axis camera gimbal, FPV flying (you see what camera sees) and ground station with waypoint flying. You can use the FPV and Ground Station via the DJI VISION App through a smart phone (iOS version 6.1 or above/ Android system version 4.0 or above). And you do not need to add anything else.
    Phantom 2 Vision has basically the same features as the Vision+, except the Vision does not have the 3-axis camera gimbal. Because of this, the camera may not be as stable and steady in some conditions.
    The Phantom 2 does not include a camera or gimbal, but can be purchased with the H3-3D gimbal as a single package. This gimbal can hold GoPro cameras, so this may be the right choice for you if you want to use your own camera to shoot footage. The Phantom 2 also does not support FPV flying or ground station waypoints without extra accessories.
    The latest Phantom 2 Vision+ and Phantom 2 comes with the new remote controller, new propulsion system and new compass.
    Can GoPro camera be used in Phantom 2 Vision+?
    No, it is not possible to use a GoPro camera with the current configuration of the Phantom 2 Vision+. We do not recommend attempting to reconfigure the system to work with any other camera.
    Do you need Wi-Fi to use the Phantom 2 Vision+?
    A Wi-Fi network is built into the Phantom. You connect to this network with your mobile device when using the Phantom. No outside Wifi connection is needed.
    Can I use an iPad rather than an iPhone for the FPV and ground station?
    Yes, you can use iPad instead of iPhone as the FPV screen via DJI VISION App, you need to download the App in "iPhone" category from the App Store of the iPad. An Internet connection is required to download the map for the ground station feature (waypoints flying). If flying in an area without internet access, you can cache the map by viewing it when an internet connection is available.
    Will the camera show views straight down?
    Yes. The camera's tilt control can be set for shooting straight down.
