• gallery
  • gallery
  • gallery
  • gallery
  • gallery
  • gallery
Phantom 3 Professional
FREE SHIPPING
  • Included 4K Video / 12 Megapixel Photo Camera
  • Integrated 3-Axis Stabilization Gimbal
  • Easy to Fly, Intelligent Flight System
  • Live HD View
  • Dedicated Remote Controller
  • Powerful Mobile App w/ Auto Video Editor
  • Vision Positioning for Indoor Flight
  • Phantom Comparison >
More
Purchase a Phantom 3 Professional and get a free extra Intelligent Flight Battery. The free extra battery is included in your order.
Free same-day delivery, setup, and flight training. Click HERE for more details.
DJI Care
DJI Care is a service plan that covers damage to DJI aircraft, gimbals or cameras sustained through normal use. More Information
{{ dji_care_title(care) }}
{{ dji_care_normal_price(care) }}{{ dji_care_price(care) }}{{ care.tips }}
OSMO Shield
OSMO Shield doubles the DJI Osmo warranty period and offers comprehensive coverage. Learn More
{{ warranty.short_title }}
More
Recommended Accessories
"The DJI Phantom 3 Professional is easy to set up, simple to fly and its stabilized camera shoots beautiful 4K footage." — The Verge
"DJI’s Phantom 3 Professional Is the Best POV Drone Money Can Buy." — outside.com, September 8, 2015
Visit Phantom 3 Professional Product Page
Aircraft
Weight (including battery and propellers)
1280 g
Diagonal size (including propellers)
590 mm
Max Ascent Speed
5 m/s
Max Descent Speed
3 m/s
Hover Accuracy
  • Vertical: +/- 0.1 m (when Vision Positioning is active) or +/- 0.5 m
  • Horizontal: +/- 1.5 m
Max Speed
16 m/s (ATTI mode, no wind)
Max Service Ceiling Above Sea Level
6000 m (Software altitude limit: 120 m above takeoff point)
Operating Temperature
0°C to 40°C
GPS Mode
GPS/GLONASS
Camera
Sensor
Sony EXMOR 1/2.3” Effective pixels: 12.4 M (total pixels: 12.76 M)
Lens
FOV 94° 20 mm (35 mm format equivalent) f/2.8, focus at ∞
ISO Range
100-3200 (video) 100-1600 (photo)
Shutter Speed
8s -1/8000s
Image Max Size
4000 x 3000
Still Photography Modes
  • Single Shot
  • Burst Shooting: 3/5/7 shots
  • Auto Exposure Bracketing (AEB): 3/5
  • Bracketed Frames at 0.7EV Bias
  • Time-lapse
Video Recording Modes
  • UHD: 4096x2160p 24/25, 3840x2160p 24/25/30
Phantom 3 Advanced
  • 2.7K: 2704 x1520p 24/25/30 (29.97)
Supported SD Card Types
Micro SD
Max capacity: 64 GB. Class 10 or UHS-1 rating required
Max Bitrate of Video Storage
60 Mbps
Phantom 3 Advanced
40 Mbps
Supported File Formats
  • FAT32/exFAT
  • Photo: JPEG, DNG
  • Video: MP4, MOV (MPEG-4 AVC/H.264)
0°C to 40°C
Gimbal
Controllable Range
Pitch -90° to +30°
Stabilization
3-axis (pitch, roll, yaw)
Vision Positioning
Max Velocity
Less than 8 m/s (when 2 m above ground)
Altitude Range
50 cm-300 cm
Operating Range
50 cm-300 cm
Operating Environment
Surface with clear pattern and adequate lighting (Lux > 15)
Remote Controller
Operating Frequency
2.400 GHz-2.483 GHz
Max Distance
Up to 5 km or 3.1 miles (unobstructed, free of interference) when FCC compliant
Up to 3.5 km or 2.1 miles (unobstructed, free of interference) when CE compliant
Video Output Port
USB
0°C- 40°C
Battery
6000 mAh LiPo 2S
Mobile Device Holder
For tablet or phone
Receiver Sensitivity (1%PER)
-101 dBm ±2 dBm
Transmitter Power (EIRP)
  • FCC: 20 dBm
  • CE: 16 dBm
Working Voltage
1.2 A @7.4 V
Battery Charger
Voltage
17.4 V
Rated Power
  • 100 W
Phantom 3 Advanced
  • 57 W
Capacity
4480 mAh
Voltage
15.2 V
Battery Type
LiPo 4S
Energy
68 Wh
Net Weight
365 g
Max Flight Time
Approximately 23 minutes
-10°C to 40°C
Max Charging Power
100 W
App / Live View
Mobile App
DJI GO
EIRP
100mW
Power Spectral Density
6.9mW/MHz
Live View Working Frequency
2.4GHz ISM
Live View Quality
720P @ 30fps (depending on conditions and mobile device)
Latency
220ms (depending on conditions and mobile device)
Required Operating Systems
  • iOS 8.0 or later
  • Android 4.1.2 or later
Recommended Devices
  • iOS: iPhone 5s, iPhone 6, iPhone 6 Plus, iPad Air, iPad Air Wi-Fi + Cellular, iPad mini 2, iPad mini 2 Wi-Fi + Cellular, iPad Air 2, iPad Air 2 Wi-Fi + Cellular, iPad mini 3, and iPad mini 3 Wi-Fi + Cellular. This app is optimized for iPhone 5s, iPhone 6, and iPhone 6 Plus
  • Android: Samsung tabs 705c, Samsung S6, Samsung S5, Samsung NOTE4, Samsung NOTE3, Google Nexus 9, Google Nexus 7 II, Ascend Mate7, Nubia Z7 mini, SONY Z3 EXPERIA, MI 3, MI PAD, Smartisan T1
What is the difference between the Phantom 3 Professional and the Phantom 3 Advanced?
The biggest difference between the Phantom 3 Professional and the Phantom 3 Advanced is in the camera. The Phantom 3 Professional is capable of shooting spectacular 4K video at up to 30 frames per second, and the Phantom 3 Advanced is capable of shooting at resolutions up to 2.7K. Both models shoot 12 megapixel photos.
The other main difference is the Intelligent Flight Battery charger. The Phantom 3 Advanced comes with a 57-watt charging unit and the Phantom 3 Professional comes with a 100-watt charger, the latter of which allows for shorter charging times. Compare the Phantom 3 Series.
Can I remove the camera and attach my own?
No. The cameras that come with both models are permanently attached. Attempting to remove, replace, or modify the camera may damage the product and will void your warranty.
Can I charge my Remote Controller and Intelligent Flight Battery at the same time?
While the Remote Controller charger and Intelligent Flight Battery charger have been integrated into one unit for your convenience, it is recommended that you only charge one item at a time. We recommend that you never charge both items using the same charger at the same time.
What are the buttons on the back of my Remote Controller for?
The two buttons on the back of the Remote Controller can be customized and assigned to function as you choose through the DJI GO app. Refer to the manual for more information.
How far can I fly my Phantom 3?
The signal transmission distance will vary depending on environmental conditions, but the Phantom 3 series can reach distances of up to 3.1 miles (5 kilometers) away from the pilot.
What app should I use with my Phantom 3?
The Phantom 3 is compatible with the DJI GO app for iOS and Android, which is already used with the DJI Inspire 1. The app will detect which aircraft is connected and automatically adjust accordingly.
Which mobile devices are compatible with the app?
The DJI GO app is only compatible with devices running iOS 8.0 or later or Android v4.1.2 or later.
The following devices are recommended:
Android: Samsung S5, Note 3, Sony Z3 EXPERIA, Google Nexus 7 II, Google Nexus 9, Mi 3, Nubia Z7 mini
Support for additional Android devices will become available as testing and development continues.
How do I use the Director automatic video editor?
Director is an automatic video editor built into the DJI GO app. After recording several video clips, simply tap “Director” from the app’s home screen. You can then select a template and a specified number of clips, which are automatically combined to create a short film that can be shared immediately.
How do I customize the sticks on my remote controller (change the control mode) for my Phantom 3?
By default, the Remote Controller is set to Mode 2. This means that the right control stick controls the movement of the aircraft and the left control stick controls the throttle and orientation of the aircraft. These controls can be changed to Mode 1 or set to a customized configuration in the DJI GO app. This is only recommended for advanced users.
Can I use a Phantom 2 Remote Controller with the Phantom 3?
No. The Phantom 2 Remote Controller is not compatible with the Phantom 3. The Phantom 3 uses an all new Remote Controller that operates at 2.4 GHz, has dedicated buttons for camera control, and has customizable buttons to fit your needs.
Can I use a Phantom 2 Intelligent Flight Battery with the Phantom 3?
No. The Phantom 3 uses a newly designed Intelligent Flight Battery with greater power. The Phantom 3 has a 4 cell battery with a capacity of 4480 mAh and a voltage of 15.2 V.
My Phantom 3 does not turn off right away, is something wrong?
This is normal. After you attempt to power off the Intelligent Flight Battery, it may remain on for a few seconds as any video data is saved to the Micro SD card. This helps prevent your data from being lost or corrupted.
Do I have to buy the Remote Controller separately?
No, there is no need to buy a separate Remote Controller. Your Phantom 3 comes with a Remote Controller that is already linked to the aircraft.
Does my Phantom 3 support dual Remote Controllers?
No. The included Remote Controller can be used to control both the aircraft and the gimbal tilt at the same time.
What does the “P, A, F” switch on the Remote Controller do?
This switch, called the Flight Mode Switch, allows you to toggle different flight modes:
P-mode, or Positioning mode, indicates that both GPS and the Vision Positioning System are active and your Phantom 3 will attempt to stabilize using both.
In A-mode, or Attitude mode, the aircraft does not use GPS or the Vision Positioning System. Only the barometer is used for stabilization. The aircraft can still return to the Home Point as long as a sufficient GPS signal is available.
F-mode, or Function mode, activates Intelligent Orientation Control (IOC) functionality. Refer to the IOC section in the Appendix of the User Manual.
By default, only P mode may be used. Refer to your user manual for instructions on unlocking the other modes.
What is the Phantom 3 flight time?
Flight times will vary depending on environmental conditions and usage patterns, but the Intelligent Flight Battery is designed to provide up to 23 minutes of uninterrupted flight time when fully charged.
How can I restore a video file if the power is turned off during recording?
Do not remove the Micro-SD card from the camera. If it has been removed, place it back in the camera. Turn the Phantom 3 on and wait approximately 30 seconds as the video file is restored.
How can I ensure that my pictures and videos will be synchronized to my iOS album?
You may need to adjust the settings of your mobile device. Open the Settings menu, select the Privacy tab, select the Photos tab, and then toggle the switch next to the DJI GO app icon. If the Pilot app has not been granted access to your albums, the photos and videos cannot be synchronized.
What should I do to land my Phantom 3 smoothly as possible?
Hover the aircraft over a flat, level surface. Slowly pull the throttle stick down until the aircraft touches the ground.
Why is the discharge time of the battery not zero, even though I have never used it?
Every battery is tested prior to being packaged and shipped. This affects the discharge time of a new battery and is the reason that the discharge time is not zero. The battery is safe to use.
Can the mobile device holder be used on the Phantom 2 series Remote Controller?
No, it cannot.
