Quickly pair the receiver and transmitters. A fully charged case provides approx. 2.4 full charges, achieving up to 28 hours of extended operating time [1].
It neatly holds two transmitters and one receiver. Each transmitter fits inside with the windscreen and either the magnet or magnetic clip attached—no need to remove them. When the transmitters are stored with the clips attached, the lid also has space for the magnets and locking audio adapter cable [2], so everything stays organized and ready to go.
Tips
Not compatible with DJI Mic, DJI Mic 2, or DJI Mic Mini.
DJI Mic 3 Charging Case × 1
DJI Mic 3 Carrying Pouch × 1
Dimensions: 106.30×42.50×59.20 mm (L×W×H)
Weight: 164.1 g (charging case only)
Battery Type: Li-ion
Battery Capacity: 1950 mAh
Battery Energy: 7.55 Wh
Battery Voltage: 3.87 V
Charging Specification: Max 5 V, 1.5-2 A
Charging Temperature: 5° to 40° C (41° to 104° F)
Operating Temperature: 5° to 45° C (41° to 113° F)
Charging Time: Approx. 1.5 hours
DJI Mic 3
1. Measured using DJI Mic 3 (2 TX + 1 RX + Charging Case) paired with a fully charged charging case, with features such as noise cancellation and internal recording off, during close-range audio recording under interference-free conditions, with both transmitters connected to the receiver and the receiver connected to a camera via the 3.5mm audio cable.
2. When storing accessories in the charging case, avoid stacking to prevent receiver screen damage.
