DJI Mic Mini (2 TX + 1 RX)
Select Option
Small, Ultralight, Discreet
High-Quality Audio With Stable Transmission
48-Hour Operation w/ Case [3]
DJI OsmoAudio™ Direct Connection for Premium Sound Quality [5]
The transmitter supports direct connection to select DJI products without a receiver, simplifying your gear and workflow.
Two-Level Active Noise Cancelling
Automatic Limiting to Prevent Audio Clipping [7]
DJI Mic USB-C Charging Cable
DJI Mic Mini Transmitter (Infinity Black)
× 2
DJI Mic Mini Receiver
DJI Mic Mini Camera Audio Cable (3.5mm TRS)
DJI Mic Mini Mobile Phone Adapter (Type-C)
× 2
DJI Mic Mini Windscreen (Black)
× 2
DJI Mic Mini Clip Magnet
× 2
× 2
DJI Mic Splitter Charging Cable
DJI Mic Mini Transmitter Charging Dock (Infinity Black)
× 2
From USD $189
From USD $199
From USD $43
From USD $159
1.1-inch touchscreen + dial
Dial + buttons
0.95-inch touchscreen
Noise Cancelling
Noise Cancelling
Noise Cancelling
32 GB, 24-bit/32-bit float Dual-file internal recording
8 GB, 24-bit/32-bit float
14-hour internal recordingReceiver: 10 hours
Charging Case: 28 hours
Receiver: 6 hours
Charging Case: 18 hours
Receiver: 10.5 hours
Charging Case: 48 hours
TimecodeLet’s Answer Your Questions
What are the updates of DJI Mic Mini compared to DJI Mic 2? Which one should I buy?
1. More compact design: DJI Mic Mini is small and ultralight, with the transmitter weighing only 10 g. [1] Compared to DJI Mic 2, it offers a more lightweight and discreet wearing experience. It supports both magnetic and clip-on wearing styles, ensuring it doesn't weigh down your collar or flip outward, making it suitable for various wearing needs.
2. Longer operating time: A transmitter and a receiver offer a maximum operating time of 11.5 and 10.5 hours, [4] respectively. A fully charged case provides about 3.6 full charges to achieve a total of 48 hours of extended use. [3] This makes the DJI Mic Mini ideal for long trips, interviews, and other intensive usage scenarios.
3. DJI Mic Mini offers two noise cancellation levels to suit different environments. The Basic level is perfect for quiet indoor settings, reducing fan, air conditioning, and reverb noises while preserving vocal clarity. The Strong level excels in noisy environments, significantly cutting ambient noise for clearer vocals.
4. Longer transmission range: Audio can be transmitted up to 400 meters, [2] and with DJI Mic Mini's powerful anti-interference capabilities, your recording remains stable and high quality even in bustling outdoor environments like a busy street or crowded event.
If you are a beginner content creator with strong needs for battery life, portability, and high-quality audio capture, DJI Mic Mini is the most cost-effective and reliable choice within the DJI Mic series.
What can I use DJI Mic Mini with?
You can use DJI Mic Mini with a range of devices, including cameras, smartphones (via Type-C/Lightning adapter or via direct Bluetooth connection)*, computers, and Osmo Mobile 6 (requires a smartphone for use).
DJI Mic Mini supports the DJI OsmoAudio™ connection ecosystem. The transmitter supports direct connection to select DJI products without a receiver, including Osmo Mobile 8, Osmo Action 6, Osmo Nano, Osmo 360, Osmo Mobile 7P, Osmo Action 5 Pro, Osmo Action 4, and Osmo Pocket 3, delivering premium audio and simplifying your gear and workflow.
For a full list of compatible devices, refer to the Downloads page on the DJI Mic Mini official webpage.
* When connecting directly to a smartphone via Bluetooth, it does not support audio recording when using with the phone's native camera; it only supports filming through third-party apps. For a list of compatible apps, refer to the Downloads page on the DJI Mic Mini official webpage.
What are the differences between different DJI Mic Mini combos? How should I choose?
DJI Mic Mini (2 TX + 1 RX + Charging Case) includes a charging case, one receiver, and two Infinity Black transmitters. It provides extended battery life and is suitable for two-person audio recording.
DJI Mic Mini (1 TX + 1 RX) includes one receiver and one Infinity Black transmitter, suitable for solo creators and other single-person audio recording scenarios.
The DJI Mic Mini Transmitter (Arctic White) and DJI Mic Mini Transmitter (Infinity Black) can be connected directly to smartphones and DJI OsmoAudio™ products.
How many recording modes does DJI Mic Mini have?
DJI Mic Mini has three recording modes: S (Stereo), M (Mono), and Ms (Mono Safety Track).
1. S: Stereo mode. Audio from the two transmitters is recorded via separate channels.
2. M: Mono mode. In Mono mode, the audio recorded by the two transmitters will be combined into one channel.
3. Ms: Mono with Safety Track mode. DJI Mic Mini will record dual tracks, with the main track at normal volume and a backup track at -6 dB to protect against distortion in cases of sudden source volume increases.
* If you use Ms (Mono Safety Track) mode, you will need to separate the tracks during post-production.
What functions does the DJI Mic Mini Charging Case provide?
The DJI Mic Mini Charging Case can be used for linking the transmitters with the receiver, as well as storing the transmitters, the receiver, and mobile phone adapters (Type-C and Lightning). When fully charged, it can charge two transmitters and one receiver approx. 3.6 times.
* The DJI Mic Mini Mobile Phone Adapter (Lightning) is sold separately.
What devices can the DJI Mic Mini transmitter connect to wirelessly? How many transmitters can these devices connect to simultaneously?
DJI Mic Mini supports the DJI OsmoAudio™ connection ecosystem. DJI Mic Mini transmitters can directly connect to select DJI products (one TX for Osmo Action 4, and up to two TX for Osmo Pocket 3, Osmo Action 5 Pro, and other compatible DJI products). Additional DJI products will be supported in the future.
DJI Mic Mini transmitters can directly connect to your smartphone via Bluetooth. When the transmitter directly connects to a smartphone, the noise cancellation level cannot be adjusted in the Mimo app and will default to the Strong level. Low Cut settings are also not supported in the Mimo app.
Does DJI Mic Mini support simultaneous charging of a mobile phone and the receiver?
Yes. When the DJI Mic Mini receiver is connected to your phone via mobile phone adapter, you can use a charging cable to charge both the mobile phone and the receiver through the receiver's USB-C port.
Where can I find the DJI Mic Mini user guide?
We recommend checking out the beginner's guide to DJI Mic Mini, which includes tutorial videos, user manual, and comprehensive instructions covering unboxing, setup, activation, and device connection.
5. DJI Mic Mini transmitters can directly connect to select DJI products (one TX for Osmo Action 4, up to two TX for Osmo Pocket 3 and Osmo Action 5 Pro). The transmitter's operating time is approx. 7 to 8 hours when directly connected. More DJI products will be supported in the future.
6. Strong and Basic noise cancellation levels can be set via the DJI Mimo app, or directly on the product interface when using an Osmo Action 5 Pro, Osmo Action 4, or Osmo Pocket 3 connected to one or more transmitters via DJI OsmoAudio™ Direct Connection. When the transmitter directly connects to a smartphone, the noise cancellation level cannot be adjusted in the Mimo app; it defaults to the Strong setting.
7. When the transmitter is used with the receiver, automatic limiting is enabled by default and can be turned on or off via the DJI Mimo app; when the transmitter is connected directly to a smartphone via Bluetooth, this feature is enabled by default and cannot be turned off. The feature can also be turned on or off directly on the product interface when using an Osmo Action 5 Pro, Osmo Action 4, or Osmo Pocket 3 connected to one or more transmitters via DJI OsmoAudio™ Direct Connection.
