DJI Mic Mini
  • Small, Ultralight, Discreet
  • High-Quality Audio With Stable Transmission
  • 48-Hour Operation w/ Case [3]
  • DJI OsmoAudio™ Direct Connection for Premium Sound Quality [5]
    The transmitter supports direct connection to select DJI products without a receiver, simplifying your gear and workflow.
  • Two-Level Active Noise Cancelling
  • Automatic Limiting to Prevent Audio Clipping [7]
  • DJI Mic Mini Transmitter (Infinity Black)
    × 2
  • DJI Mic Mini Receiver
  • DJI Mic Mini Charging Case
  • DJI Mic Mini Camera Audio Cable (3.5mm TRS)
  • DJI Mic Mini Mobile Phone Adapter (Type-C)
  • DJI Mic Mini Windscreen (Black/Gray)
    × 2
  • DJI Mic Mini Windscreen (Black)
    × 2
  • DJI Mic Mini Clip Magnet
    × 2
  • DJI Mic Mini Carrying Pouch
  • DJI Mic Mini Mobile Phone Adapter (Lightning)
DJI Mic 3
DJI Mic 2
DJI Mic Mini
DJI Mic 3 (2 TX + 1 RX + Charging Case)
DJI Mic 2 (2 TX + 1 RX + Charging Case)
DJI Mic Mini (1 TX + 1 RX)
DJI Mic (2 TX + 1 RX + Charging Case)
DJI Mic 3
DJI Mic 2
DJI Mic Mini
Wireless Microphone for Pro-Level Audio
Mini Wireless Microphone
Compact Magnetic Wireless Microphone
From USD $169
From USD $129
From USD $59
From USD $159
16 g (with magnet)Transmitter Weight
28 gTransmitter Weight
10 gTransmitter Weight
30 gTransmitter Weight
img1.1-inch touchscreen + dial
imgDial + buttons
img0.95-inch touchscreen
imgNoise Cancelling
imgNoise Cancelling
imgNoise Cancelling
Adaptive Gain ControlAutomatic (clipping prevention) Dynamic (volume balancing)
Adaptive Gain ControlAutomatic Limiting to Prevent Audio Clipping
img32 GB, 24-bit/32-bit float Dual-file internal recording
img8 GB, 24-bit/32-bit float
img14-hour internal recording
28-hour operating timeTransmitter: 8 hours
Receiver: 10 hours
Charging Case: 28 hours
18-hour operating timeTransmitter: 6 hours
Receiver: 6 hours
Charging Case: 18 hours
48-hour operating timeTransmitter: 11.5 hours
Receiver: 10.5 hours
Charging Case: 48 hours
15 hoursTotal Operating Time
Three voice tone presetsVoice Tone Presets
Four transmitters, eight receiversConnection Capability
Two transmitters, one receiverConnection Capability
imgTimecode
5. DJI Mic Mini transmitters can directly connect to select DJI products (one TX for Osmo Action 4, up to two TX for Osmo Pocket 3, Osmo Action 5 Pro, and other compatible DJI products). The transmitter's operating time is approx. 7 to 8 hours when directly connected. Additional DJI products will be supported in the future.
6. Strong and Basic noise cancellation levels can be set via the DJI Mimo app, or directly on the product interface when using a compatible DJI product connected to one or more transmitters via DJI OsmoAudio™ Direct Connection. When the transmitter directly connects to a smartphone, the noise cancellation level cannot be adjusted in the Mimo app; it defaults to the Strong setting.
7. When the transmitter is used with the receiver, automatic limiting is enabled by default and can be turned on or off via the DJI Mimo app; when the transmitter is connected directly to a smartphone via Bluetooth, this feature is enabled by default and cannot be turned off. The feature can also be turned on or off directly on the product interface when using a compatible DJI product connected to one or more transmitters via DJI OsmoAudio™ Direct Connection.
