Osmo Pocket 3 Vlog Combo (DJI Mic Mini Transmitter Arctic White)
Select Option
Powerful 1-Inch Sensor
A large CMOS sensor and 4K/120fps [1] UHD footage capture experiences in dynamic, buttery smooth detail.
Three-Axis Stabilization
Shoot smooth, stable hand-held footage. Cater to your scene by adjusting Osmo Pocket 3's Rotational Speed to track different-paced scenarios.
2-Inch Rotatable Touchscreen
With the upgraded OLED touchscreen, you can easily switch between horizontal and vertical shooting or tap to adjust parameters and subject tracking.
Full-Pixel Fast Focusing
Lock a subject in focus, even while moving. The new Product Showcase mode prioritizes focusing on the foreground - perfect for livestreaming.
ActiveTrack 6.0, Stay Centered
Shoot like a pro by utilizing follow modes like Face Auto-Detect, Dynamic Framing, and more to lock your subject in frame as you move the camera.
Sound That Surrounds
Get it clear the first time with omnidirectional stereo recording and the ability to connect to two DJI Mic 2 Transmitters.
10-Bit D-Log M Color
With D-Log M and 10-bit color depth, you can effortlessly record up to one billion colors and achieve stunning visual effects during post-production.
DJI OsmoAudio™
OsmoAudio™ connection delivers premium audio. It allows Pocket 3 to directly connect to two DJI Mic 2/Mic Mini transmitters, simplifying your gear and workflow.
Osmo Pocket 3
DJI Mic Mini Transmitter (Arctic White)
Osmo Pocket 3 Handle With 1/4″ Thread
DJI Mic Mini Transmitter Charging Dock(Arctic White)
DJI Mic USB-C Charging Cable
Type-C to Type-C PD Cable
Osmo Pocket 3 Protective Cover
DJI Wrist Strap
DJI Mic Mini Windscreen (Gray)
DJI Mic Mini Clip Magnet
Moments By You
From USD $409
From USD $349
Image Sensor
Image Sensor
ActiveTrack 6.0
ActiveTrack 3.0
Stereo Recording
Stereo RecordingLet’s Answer Your Questions
What are the major upgrades of Osmo Pocket 3 compared with DJI Pocket 2?
Compared with DJI Pocket 2, Osmo Pocket 3 has greatly improved in imaging performance, shooting experience, and intelligent features:
1. Imaging performance: The sensor has been upgraded from 1/1.7 inches to 1 inch to deliver high-resolution footage in various scenarios, low-noise night shots, high-dynamic range capabilities in high-contrast scenarios, and support for 4K/120fps.
2. Shooting experience: The upgraded 2-inch OLED screen delivers richer colors and higher contrast. The larger image size presents clearer details, and both horizontal and vertical shots can be displayed on full screen. Simply double-tap your subject on the screen to start tracking or rotate the screen to quickly power on or off the device, greatly optimizing your shooting experience. Pocket 3 features built-in Wi-Fi for direct connection to a smartphone without the Do-It-All Handle, quickly achieving photo/video transfer, editing, and sharing.
3. Intelligent features: ActiveTrack has been upgraded to 6.0, achieving a perfect combination of mechanical gimbal and intelligent tracking algorithms. No matter how you hold the device or move the camera, the tracked subject stays centered and in focus while the camera view moves stably and smoothly.
With the new Face Auto-Detect mode, you can effortlessly record single-person vlogs. After the subject enters the frame, the camera will automatically recognize and smoothly track them throughout the shooting process to keep them at the center.
With the new Dynamic Framing mode, you don’t need to hold and move the device to keep the subject in the center or the required position. Enable Dynamic Framing, and you can lock the subject in the required position, avoiding the difficulty of trying to manually center the subject while improving creative efficiency.
What accessories does Osmo Pocket 3 support?
Osmo Pocket 3 has added the following practical accessories, further enhancing your experience in shooting, storage, operating time, and more:
Osmo Pocket 3 Black Mist Filter
Osmo Pocket 3 Battery Handle
Osmo Mini Tripod
Osmo Pocket 3 Magnetic ND Filters Set
Osmo Pocket 3 Expansion Adapter
Osmo Pocket 3 Wide-Angle Lens
Osmo Pocket 3 Carrying Bag
Please note that Osmo Pocket 3 does not support the exclusive accessories of previous-generation products.
What microSD cards does Osmo Pocket 3 support?
Recommended microSD cards:
SanDisk Extreme Pro 32GB V30 A1 UHS-I Speed Grade 3
Kingston Canvas Go!Plus 256GB UHS-I Speed Grade 3
Kingston Canvas Go!Plus 512GB UHS-I Speed Grade 3Kingston Canvas React Plus 64GB UHS-II Speed Grade 3
Kingston Canvas React Plus 256GB UHS-II Speed Grade 3Lexar Pro 256GB SDXC UHS-I V30 R160/W120 (1066x)
Lexar SILVER PLUS microSDXC UHS- I 64GB
Lexar SILVER PLUS microSDXC UHS- I 128GB
Lexar SILVER PLUS microSDXC UHS- I 256GB
Lexar SILVER PLUS microSDXC UHS- I 512GB
Lexar SILVER PLUS microSDXC UHS- I 1TBWhat Timelapse modes are available on Osmo Pocket 3? What parameters can be customized?
There are three modes: Hyperlapse, Timelapse, and Motionlapse.
In Hyperlapse mode, you can set the resolution, frame rate, and speed.
In Timelapse mode, you can set the resolution, frame rate, interval, and duration.
In Motionlapse mode, you can set the resolution, frame rate, interval, duration, and waypoints.
What is Osmo Pocket 3's color mode D-Log M?
D-Log M is designed to capture a wide dynamic range from the sensor, and colors are distributed evenly so the bright and dark parts of the video have greater fidelity and clarity. It is not a LUT but a lower-contrast video with a flat color profile, which is great for expanding post-processing options.
Can Osmo Pocket 3 shoot slow-motion videos?
Yes, it supports shooting up to 1080p/240fps 8x slow-motion and 4K/120fps 4x slow-motion videos.
Does Osmo Pocket 3 support livestreaming? What platforms does it support?
Yes. It supports YouTube and RTMP platforms.
Is Osmo Pocket 3’s 1-inch sensor the same as DJI Air 2S?
No. Osmo Pocket 3 features an all-new 1-inch stacked CMOS sensor, which supports up to 4K/120fps uncropped recording (available only in Slow Motion mode) and full-pixel PDAF, delivering enhanced overall performance.
How do I use LightCut for quick editing?
Launch LightCut, enter One-Tap Edit and select the videos you have shot. One-Tap Edit will automatically recommend templates according to your videos, which are optimized for many scenarios, including nature, city, home, shopping, food, pets, festivals, and more, and will intelligently select clips and generate a short video with no manual editing required.
You can also try other templates, change the selected clips, or select music, filters, text, and stickers to share polished videos with ease.
1. 4K/120fps video recording is only supported in Slow Motion mode.
