bannerimg
Deliver to
Out of Stock
USD $279
Out of Stock
DJI Action 2
  • Remain in the Moment
    This diverse and wearable action camera keeps your hands free, so you can live in the moment as you capture the world around you.
  • Upgraded Stabilization
    No matter how wild the action gets, DJI's latest stabilization technology RockSteady 2.0 and HorizonSteady detect and correct camera shake and rotation in real-time.
  • Made for Action, and So Much More
    The magnetic design lets you freely snap and switch between powerful modules and accessories. From daily life to the extreme, Action 2 has you covered.
  • Industry-leading Performance
    DJI Action 2 shoots 4K/120fps [2] video and offers an ultra-wide 155° FOV. Capture more of your surroundings with smooth, detailed footage.
  • A Rugged Companion
    Built tough, the DJI Action 2 Camera Unit is drop-proof, dustproof, and waterproof at depths of up to 10 meters. [1]
  • DJI Action 2 Camera Unit
  • DJI Action 2 Front Touchscreen Module
  • DJI Action 2 Magnetic Lanyard
  • DJI Action 2 Magnetic Ball-Joint Adapter Mount
  • DJI Action 2 Magnetic Adapter Mount
  • Power Cable
    Power Cable
1. ONLY THE ACTION 2 CAMERA UNIT IS WATERPROOF. THE FRONT TOUCHSCREEN MODULE AND POWER MODULE ARE NOT WATERPROOF. It is recommended to use the DJI Action 2 Waterproof Case if you intend on using DJI Action 2 underwater for long periods (such as when diving) or under high water pressure conditions (such as when cliff diving). The DJI Action 2 Camera Unit and its Waterproof Case have an IP68 waterproof rating. Do not use the camera in hot springs or expose it to corrosive liquids.
2. When recording 4K/120fps, Action 2 will stop filming when the set Auto-Stop Rec Temp is reached. If set as Standard, 4K/120fps video can be recorded for around 3 minutes. If set to High, 4K/120fps video can be recorded for around 5 minutes.
*DJI Mimo is required for activation when using DJI Action 2 for the first time.
We Value Your Privacy
Cookie Preferences
