bannerimg
Deliver to
Out of Stock
19 €
Out of Stock
DJI Action 2
The DJI Action 2 Magnetic Protective Case helps prevent damage to the Camera Unit from impact, scratches, and abrasions. An additional case is compatible with the Front Touchscreen Module and Power Module. Comprised of a heat-resistant polymer, the Magnetic Protective Case also optimizes video recording. DJI Action 2 automatically detects when the case is mounted, activating a heat control solution that increases recording length under normal conditions.
Highlights
Prevents damage from impact, scratches, and abrasions. Heat resistant to increase recording length under normal circumstances.
Tips
1. Before mounting the Magnetic Protective Case, wipe away any water or stains around the mounting points to prevent electrical problems and corrosion.
2. Mounting the Magnetic Protective Case will not affect the power and data communication of the DJI Action 2 Camera Unit, Front Touchscreen Module, or Power Module.
3. Before recording, make sure that the Magnetic Protective Case is securely mounted. Do not remove the protective case while DJI Action 2 is powered on.
4. To remove the Magnetic Protective Case, push the camera unit or expansion module away from the case.
5. Due to local regulations, some regions can only select the standard 48 °C Auto-Stop Rec Temp.
6. Remove the Magnetic Protective Case from the Camera Unit when using the DJI Action 2 Waterproof Case, DJI Action 2 Macro Lens, or DJI Action 2 Magnetic Headband.
7. It is recommended to remove the Power Module or the Front Touchscreen Module in biking, vehicle mount or other fast-moving scenarios.
8. When using DJI Action 2 in salt water, remove the Magnetic Protective Case.
Magnetic Protective Case ×1
(Includes two shells: One for the Camera Unit ×1 and one for the Front Touchscreen Module or Power Module ×1)
DJI Action 2 Front Touchscreen Module
DJI Action 2 Power Module
We Value Your Privacy
Cookie Preferences
Have questions? Get help from a DJI expert.
