bannerimg
Deliver to
Estimated shipping date: Apr. 23, expected arrival date: Apr. 28
USD $75
DJI Action 2
This module increases Action 2's battery life, includes a built-in microSD card slot, and can be used with an external microphone. With the magnetic lock, this hot-swappable module can be attached to the Camera Unit, allowing you to get more out of your Action 2. When connected, your Action 2 can film for up to 180 minutes, so you can fully enjoy recording without missing a beat.
Highlights
When connected, Action 2 can film for up to 180 minutes and gains a microSD card slot. It’s even hot-swappable and can be used with an external microphone.
Tips
The Power Module is not waterproof or dustproof and should be used with the Waterproof Case for underwater activities.
DJI Action 2 Power Module
Dimensions: 39×41.6×21.4 mm
Weight: 56.6 g
Built-In Battery
Battery Type: LiPo 2S
Capacity: 1300 mAh
Energy: 5 Wh
Voltage: 7.7 V
Charging Temperature: 0° to 40° C (32° to 104° F)
Charging Temperature: 5° to 60° C (41° to 140° F)
Operating Time*: Camera Unit + Power Module: 180 minutes
Charging Time**: Camera Unit + Power Module: 90 minutes
*Tested in a laboratory environment while recording 1080p/30fps (Power Reserve) video with electronic image stabilization disabled and should be used for reference only.
**Tested in a laboratory environment when using a 5V/2A USB adapter and should be used for reference only.
DJI Action 2
We Value Your Privacy
Cookie Preferences
