DJI Action 2 Waterproof Case
The case can house the Camera Unit plus the Front Touchscreen Module or Power Module at depths of up to 60, so you can push the limits of your aquatic adventures. A high-strength glass ensures a clear display, even while underwater.
Waterproof at depths of up to 60 m with high-strength glass for clear display.
Please make sure that the case is dry before use (it is recommended to put in an anti-fog cotton sheet to prevent fogging) and the locking screw is properly installed.
Ensure that the waterproof sealing ring is clean and intact and is firmly installed. It is recommended to place the waterproof case underwater for approximately 5 minutes to ensure it is working properly before using.
When in use, the power/record button of Action 2 can be triggered by the button of the Waterproof Case.
DJI Action 2 Waterproof Case × 1
Weight: 88 g
Dimensions: 108×64×33 mm
DJI Action 2
