bannerimg
Deliver to
Estimated shipping date: Mar. 30, expected arrival date: Apr. 1
USD $398USD $518
DJI Air 3
DJI Power 500 has a battery capacity of 512 Wh to provide a max output power of 1000 W, and can fast charge DJI Air 3/3S batteries. DJI Power SDC to DJI Air 3 Series Fast Charge Cable has a fast charging power of 125 W. It can charge a DJI Air 3/3S Intelligent Flight Battery from 0% to 100% in approx. 44 minutes, and from 10% to 95% in about 30 minutes.
With DJI 65W Portable Charger, it takes approx. 80 minutes to charge the battery from 0% to 100%. When using the DJI 100W USB-C Power Adapter in conjunction with the battery charging hub, it takes approx. 60 minutes to charge from 0% to 100%.
Tips
After a flight, the battery temperature may be high and potentially outside the permissible temperature range for immediate charging. In such cases, it is recommended to wait until the battery temperature drops below 40° C (104° F) before initiating a charge.
DJI Power 500
DJI Power AC Power Cable ×1
DJI Power SDC to DJI Air 3 Series Fast Charge Cable × 1
DJI Power 500:
Capacity: 512 Wh
Weight: Approx. 7.3 kg
305×207×177 mm (L×W×H)
AC Output:
DYM500H: AC 220-240 V, 50/60 Hz, rated: 800 W, max continuous output: 1000 W
* Max continuous output power is available when the product's battery level is above 20%. AC output data varies by country and region.
DJI Power SDC to DJI Air 3 Series Fast Charge Cable Length: 40 cm
DJI Air 3S (Update the firmware of the DJI Power series product to the latest version before using it together. View the tutorial video)
DJI Air 3
We Value Your Privacy
Cookie Preferences
