DJI Air 3S
  • 1″ CMOS Primary Camera
    14 stops of dynamic range, [1] 3.2μm large pixel size, [2] 24mm format equivalent, and 50MP resolution, capture vast landscapes day and night.
  • 70mm Medium Tele Camera
    48MP 1/1.3" CMOS sensor, matching the primary camera's video specs and color modes while offering 3x optical zoom for expressive portrait shots.
  • Dual-Camera 4K/60fps HDR Video
    Uses H.265 encoding while supporting 4K/60fps HDR video, 4K/120fps video, [3] and 10-bit D-Log M color mode.
  • Free Panorama
    Capture seamless panoramic shots with Free panorama mode, which stitches together multiple images with a manually selected subject or area.
  • Nightscape Omnidirectional Obstacle Sensing
    Forward-facing LiDAR, downward infrared ToF sensor, and three pairs of vision sensors allow nightscape [4] to detect and avoid obstacles.
  • Next-Gen Smart RTH With Enhanced Precision
    DJI Air 3S can memorize flight paths in well-lit environments [5] for safe returns, even when taking off from areas without satellite signals.
  • 45-Min Flight Time
    With up to 45 minutes of flight time [6], Air 3S gives you enough time to scout locations, compose, nail your shots, and do it all over again and again.
  • 20km Video Transmission
    DJI O4 video transmission provides 10-bit video transmission at 1080p/60fps for distances up to 20 km, [7] offering smoother live feeds.
  • DJI Air 3S
    DJI Air 3S
  • DJI RC 2 Remote Controller
  • Intelligent Flight Battery
    × 3
  • Battery Charging Hub
  • ND Filter Set (ND8/32/128)
  • Spare Propellers (Pair)
  • Type-C to Type-C PD Cable
  • Gimbal Protector
    Gimbal Protector
Moments By You
* All videos and images on this page were shot using DJI Air 3S by professionals in strict compliance with local laws and regulations and have been variously edited in post-production. All videos and images are for reference only. Actual results may vary. Always observe local laws and regulations and ensure the aircraft has obtained relevant certifications and airspace authorizations before flying.
** All data on this page was collected with a production model of DJI Air 3S in a controlled test environment. Actual experience may vary depending on the environment, usage, and firmware version. DJI Air 3S must be activated via the DJI Fly app before use.
*** It is recommended to use the ActiveTrack 360° feature in open environments. Refer to the user manual for unsupported scenarios or those that may potentially interrupt recording. In complex environments with many obstacles, exercise caution when using Auto mode to ensure flight safety and personal safety.
**** All images, videos, and screen display contents about the product itself on this page are for reference only. Actual product effects (including but not limited to appearance, color, and size) and screen display contents (including but not limited to backgrounds, UI, and illustrations) may vary.
1. 14 stops of dynamic range are achievable for video on Auto mode but not for vertical or slow-motion video.
2. Achieved with QBC (Quad Bayer Coding) techniques that combine four pixels into one. Not supported when shooting 48MP or 50MP photos.
3. 4K/120fps video recording is only supported in Slow Motion mode.
4. Conditions for enabling nightscape omnidirectional obstacle sensing: The drone's front, back, left, right, or top sides are within range of surfaces with discernible textures with illuminance that exceeds 1 lux. Similarly, the ground below is textured and diffusely reflective with a reflectivity above 20% (such as walls, trees, or people), also in lighting conditions with illuminance higher than 1 lux. DO NOT fly in severe weather conditions, such as in strong winds (wind speed of 12 m/s or more), snow, rain, lightning, or fog. DO NOT fly the aircraft 6,000 m (19,685 ft.) or higher above sea level. DO NOT fly the aircraft in environments where the temperature is below -10° C (14° F) or above 40° C (104° F). DO NOT take off from moving objects, such as cars or boats. DO NOT fly close to reflective surfaces such as water or snow. Otherwise, the vision system may not work correctly. When GNSS signals are weak, fly the aircraft in well-lit environments: the drone's front, back, left, right, and top sides are within range of surfaces with discernible textures with illuminance that exceeds 10 lux. Similarly, the ground below is textured and diffusely reflective with a reflectivity above 20%, also in lighting conditions with illuminance higher than 10 lux. The vision system may not work properly in dim environments. DO NOT fly near areas with magnetic or radio interference. Familiar magnetic or radio interference sources include Wi-Fi hotspots, routers, Bluetooth devices, high-voltage lines, large-scale power transmission stations, radar stations, mobile base stations, and broadcasting towers. Avoid sand entering the aircraft when taking off in desert or beach areas. Fly the aircraft in open areas away from crowds. Buildings, mountains, and trees may block the GNSS signal and affect the onboard compass.
5. Conditions for memorizing flight paths: The drone's front, back, left, right, and top sides are within range of surfaces with discernible textures with illuminance that exceeds 10 lux. Similarly, the ground below is textured and diffusely reflective with a reflectivity above 20% (such as walls, trees, or people), also in lighting conditions with illuminance higher than 10 lux. If the drone is taking off from a balcony, ensure the usable space is at least 2 meters by 2 meters, and the height above ground is less than 30 meters to ensure a safe return to home.
6. Measured by DJI Air 3S flying forward at a constant speed of 32.4 kph in a windless environment at sea level, with Obstacle Avoidance Action set to Brake, in photo mode, and from 100% battery level until 0%. Data is for reference only. Always pay attention to reminders in the app during your flight.
