bannerimg
Deliver to
Free express shipping arrival date: May 12
USD $999USD $1,087
DJI Avata 2
  • FPV Flight Experience
    DJI Goggles 3 has HD micro-OLED displays and low video latency. It also has Real View PiP, for awareness without removing the goggles.
  • Easy ACRO
    RC Motion 3 allows for stunning flying acrobatics simply with one push, including front/back flips, sideways rolls and 180° drifts.
  • Tight Shots in Super-Wide 4K
    Capture the thrill of flight with crisp 4K/60fps HDR video. [1] Enjoy a 155° ultra-wide-angle FOV that enhances low-altitude, high-speed flying.
  • 1/1.3-inch Image Sensor
    The upgraded 1/1.3-inch image sensor [2] expands the dynamic range, handling low-light more effectively to get great footage.
  • Built-in Propeller Guard
    Avata 2 combines the body and propeller guard, for more protection. Lighter and more agile, [2] it can showcase your skills.
  • Turtle Mode
    Avata 2 can flip itself into takeoff position with Turtle mode, so you can get airborne again.
  • Binocular Fisheye Visual Positioning
    Binocular fisheye sensors enable downward and backward visual positioning for low-altitude and indoor flights, enhancing stability and safety.
  • One-Tap Sky VFX
    With the LightCut app, you can add Sky VFX, or use One-Tap Edit and a range of templates in the post to easily create engaging aerial footage.
  • DJI Avata 2
    DJI Avata 2
  • DJI Goggles 3
    DJI Goggles 3
  • DJI RC Motion 3
    DJI RC Motion 3
  • DJI Avata 2 Intelligent Flight Battery
  • DJI Avata 2 Propellers (Pair)
    × 4
  • DJI Avata 2 Propeller Screw
    × 16
  • DJI Avata 2 Gimbal Protector
  • DJI Goggles 3 -2.0D Corrective Lenses (Pair)
  • USB-C OTG Cable
    USB-C OTG Cable
  • Type-C to Type-C PD Cable
  • DJI RC Motion 3 Lanyard
  • Screwdriver
    Screwdriver
1. HDR video is only available with the following shooting specifications: When EIS is turned off, using a 16:9 aspect ratio and recording at 4K/2.7K/1080p@60/50/30fps, or using a 4:3 aspect ratio and recording at 4K/2.7K/1080p@30fps; When EIS is set to RockSteady or HorizonSteady, using either a 16:9 or 4:3 aspect ratio and recording at 4K/2.7K/1080p@30fps.
2. Compared to DJI Avata.
We Value Your Privacy
Cookie Preferences
