DJI Avata Fly More Kit
At a better price than buying separately, DJI Avata Fly More Kit includes two Intelligent Flight Batteries and a Battery Charging Hub, providing sufficient power for your flight.
The Intelligent Flight Battery has a rated capacity of 35.71 Wh and a powerful battery life of approximately 18 minutes*. With a built-in DJI Intelligent Battery Management System, battery status is monitored and reported in real-time, allowing you to focus less on power levels and more on flying.
The DJI Avata Battery Charging Hub can charge four batteries in sequence, which greatly enhances the charging efficiency.
* Tested when hovering in an environment without wind or interference.
DJI Avata Intelligent Flight Battery × 2
DJI Avata Battery Charging Hub × 1
DJI Avata Intelligent Flight Battery:
Battery Capacity: 2420 mAh
Nominal Voltage: 14.76 V
Charging Voltage Limit: 17 V
Battery Type: Li-ion
Energy: 35.71 Wh@0.5C
Discharge Rate: 7C (typical)
Weight: Approx. 162 g
Charging Temperature Range: 5° to 40° C (41° to 104° F)
DJI Avata Battery Charging Hub:
Operating Temperature Range: 5° to 40° C (41° to 104° F)
Recommended Charger: DJI 65W Portable Charger or other USB PD chargers
Input: 5-20 V, max 5 A
Output: 17 V
Charging Time: Approx. 47 mins (tested using the DJI 65W Portable Charger and subject to temperature)
