The Intelligent Flight Battery has a rated capacity of 35.71 Wh and a powerful battery life of approximately 18 minutes*. With a built-in DJI Intelligent Battery Management System, battery status is monitored and reported in real-time, allowing you to focus less on power levels and more on flying.
* Tested when hovering in an environment without wind or interference.
DJI Avata Intelligent Flight Battery × 1
Battery Capacity: 2420 mAh
Nominal Voltage: 14.76 V
Charging Voltage Limit: 17 V
Battery Type: Li-ion
Energy: 35.71 Wh@0.5C
Discharge Rate: 7C (typical)
Weight: Approx. 162 g
Charging Temperature Range: 5° to 40° C (41° to 104° F)
