Deliver to
Estimated shipping date: Apr. 28, expected arrival date: Apr. 29
USD $99
31-min* max flight time. Be prepared and fly freely with peace of mind.
Intelligent Flight Battery × 1
Model: BWX141-3110-7.16
Weight: Approx. 83.5 g
Capacity: 3110 mAh
Nominal Voltage: 7.16 V
Max Charging Voltage: 8.6 V
Battery Type: Li-ion
Energy: 22.3 Wh
Charging Time:
70 minutes (with the DJI 30W USB-C Charger and the battery mounted to the aircraft)
45 minutes (with the DJI 65W USB-C Charger and 1 battery inserted into the Parallel Charging Hub)
70 minutes (with the DJI 65W USB-C Charger and 2 batteries inserted into the Parallel Charging Hub)
Charging Temperature: 41° to 104° F (5° to 40° C)
It is recommended to use the DJI 65W USB-C Charger or other USB Power Delivery chargers.
* Measured when flying forward at a constant speed of 6 m/s in a windless environment 20 m above sea level, in photo mode (without taking photos), and from 100% battery level until 0%. Results may vary depending on the environment, actual use, and firmware version.
We Value Your Privacy
Cookie Preferences
