DJI FPV Fly More Kit
Out of stock
The DJI FPV Fly More Kit contains two DJI FPV Intelligent Flight Batteries and a DJI FPV Battery Charging Hub for extended flight time.
The rated capacity for each battery is up to 44.4 Wh, supporting flight for approximately 20 minutes. The built-in intelligent battery management system monitors battery status in real-time for a more worry-free flight.
Use the charging hub to charge up to three batteries in sequence.
Save more with the Fly More Kit.
Two Intelligent Flight Batteries for a longer flight.
Charge multiple batteries at once.
DJI FPV Intelligent Flight Battery ×2
DJI FPV Battery Charging Hub ×1
Battery Capacity: 2000 mAh
Voltage: 22.2 V
Max Charging Voltage: 25.2 V
Battery Type: LiPo 6S
Energy: 44.4 Wh@0.5C
Discharge Rate: Standard: 10C
Weight: 295 g
Charging Temperature: 5° to 40° C (41° to 104° F)
Max Charging Power: 90 W
DJI FPV Drone
