With the DJI FPV Remote Controller, parameters of each component can be adjusted remotely. Purchasing the DJI FPV Goggles and the DJI FPV Air Unit eliminates the need of any additional receiver. Users can also enjoy 7ms ultra-low latency between the remote controller and the air unit.
Tips
It is recommended to use the USB adapter of DJI Goggles RE, Ronin-S, Spark or an FCC/CE certified USB adapter that supports Quick Charge 2.0.
If you use the DJI FPV Goggles and the DJI FPV Remote Controller at the same time, you must first link the air unit and the goggles, and then link the remote controller.
DJI FPV Remote Controller (including the battery) × 1
Remote Controller
Weight: 765 g
Operation Frequency: 5.725-5.850 GHz
Max. Transmission Distance (Unobstructed,free of interference): FCC/SRRC: 4 km; CE: 0.7 km
Transmitter Power (EIRP): FCC: <30 dBm; CE: <14dBm; SRRC:<19dBm
Operation Current/Voltage: 0.6 A @ 7.6 V
Operation Temperature: 0° to 40°C (32° to 104°F)
Charging Temperature: 5° to 40°C (41° to 104°F)
Remote Controller Intelligent Battery
Battery Type: LiPo 2S
Capacity: 4920 mAh
Voltage: 7.6 V
Energy: 37.39 Wh
DJI FPV Air Unit
DJI FPV Goggles
