DJI Goggles 2 Motion Combo
DJI Goggles 2 is lightweight, portable, and comfortable to wear. The goggles adopt two 1080p Micro-OLED screens with a refresh rate of up to 100 Hz. * Together with a 10-bit enhanced display, the goggles can smoothly deliver true-to-life colors and accurate highlight-shadow details. When using the goggles with DJI Motion Controller, you can enjoy easy and intuitive motion control for an immersive flight experience as if you were in the pilot seat.
The goggles support diopter adjustment from -8.0 D to +2.0 D as well as ultra-low-latency DJI O3+ video transmission, providing a more immersive flight, and unlocking new ways to capture aerial shots.
The goggles support Wi-Fi wireless streaming to display videos from mainstream video software using DLNA protocol. And with a power amplifier and a 3.5 mm audio port, you can output synchronous audio for immersive movie-watching.
* The screen refresh rate changes with the video transmission frame rate. It may switch between 100 Hz and 60 Hz to adapt to the current video transmission frame rate.
DJI Goggles 2 × 1
DJI Goggles 2 Battery × 1
DJI Goggles 2 Eyeglass Frames (Pair) × 1
DJI Goggles 2 Screen Protector × 1
DJI Goggles 2 Headband × 1
DJI Goggles 2 Power Cable × 1
DJI Goggles 2 Dual-Band Antenna × 1
OTG Cable × 1
DJI Motion Controller × 1
Lanyard × 1
