  • Compact, Portable, Stress-Free
    DJI Goggles 2 weighs only 290 g, making it easy to travel with and comfortable to wear. Soft foam padding fits your face to reduce light leakage.
  • Convenient Adjustable Diopters
    DJI Goggles 2 supports diopter adjustment from +1.0 to -8.0 D. [1] Customize and go glasses-free without compromising on display quality.
  • Stunning Dual-HD Screens
    1080p Micro-OLED screens feature a refresh rate of up to 100 Hz. [2] A 10-bit enhanced display delivers true-to-life colors and shadow details.
  • Ultra-Low Latency Transmission
    DJI O3+ video transmission has strong anti-interference, can automatically switch to a more stable signal, and has latency as low as 30 ms. [3]
  • Experience Immersive Movies
    Use Wi-Fi wireless streaming to watch videos from mainstream video software. A 3.5mm audio port allows synchronous audio for an in-home theater.
  • DJI Goggles 2
  • DJI Goggles 2 Battery
  • DJI Goggles 2 Eyeglass Frames (Pair)
  • DJI Goggles 2 Screen Protector
  • DJI Goggles 2 Headband
  • DJI Goggles 2 Power Cable
  • DJI Goggles 2 Dual-Band Antenna (Pair)
  • DJI Goggles 2 OTG Cable
DJI Goggles 2
Compact and Lightweight Immersive Flight Goggles
Approx. 290 g
With antennas folded: 167×104×81 mm
Head Tracking
1920×1080 Micro-OLED screens
TÜV Rheinland Low Blue Light Certification
700-nits max brightness
H.264 and H.265 video transmission decoding capability
Diopter adjustment from +2.0 to -8.0 D
1080p/100fps video transmission quality: the latency as low as 30 ms
1080p/60fps video transmission quality: the latency as low as 40 ms
Wi-Fi wireless streaming supporting DLNA protocol
120-min max operating time
2.4 GHz, 5.8 GHz
DJI FPV Goggles V2
Approx. 420 g
With antennas folded: 184×122×110 mm
1440×810 LCD screens
360-nits max brightness
H.264 video transmission decoding capability
810p/120fps video transmission quality: the latency of less than 28 ms
810p/60fps video transmission quality: the latency of less than 40 ms
110-min max operating time
2.4 GHz, 5.8 GHz
1. Astigmatism adjustment is not supported. If you have specific vision requirements, please consult your doctor before use.
2. The screen refresh rate changes with the video transmission frame rate. It may switch between 100 Hz and 60 Hz to adapt to the current video transmission frame rate.
3. When used with DJI Avata or DJI O3 Air Unit, DJI Goggles 2 can achieve O3+ video transmission. The latency data is tested with 1080p/100fps video transmission quality and in an outdoor open environment without interference.
Got questions?Let us help you.
