bannerimg
Deliver to
Estimated shipping date: Mar. 31, expected arrival date: Apr. 7
USD $499
DJI Avata 2
Immersive Flight, Broaden Your Horizons
Pair it with DJI RC Motion 3 to get a fully immersive motion control experience, or use it with the RC-N2 or RC 2 remote controllers to pilot a 3-axis-gimbal camera drone. All this delivers silky-smooth live feeds so you can fully enjoy the FPV flying experience.
O4 Video Transmission, Compatible with Air 3 and Mini 4 Pro
With Avata 2, O4 video transmission delivers ultra-low latency at 24 ms and a high bitrate of 60Mbps. Also compatible with Air 3 and Mini 4 Pro, the reliable O4 HD transmission offers crystal-clear and fluid first-person views.
Real View PiP, Safety in Sight
Without removing your goggles, you can now conveniently observe your surroundings to get enhanced flight safety.
All-Around Comfort and Convenience
Dazzling Upgrades: Enjoy a 1080p Micro-OLED screen with a refresh rate of up to 100 Hz*, alongside the TüV Rheinland Low Blue Light Certification. Accommodates diopter adjustments from -6.0 D to +2.0 D for nearsighted and farsighted users.
Battery and Headband Integration: The lightweight, comfortable design that integrates the headband liberates you from tangled cables and offers a lengthy 3-hour operating time.**
One-Tap Defogging: With defogging enabled, you get a convenient solution for sudden changes in temperature or high-humidity conditions.
More Fun with Wireless Streaming
Stream your flight in real-time on the DJI Fly app of your smartphone via Wi-Fi connection.***
You can also import panoramic and 3D videos onto an SD card and play them back using Goggles 3 for an immersive experience that seems almost within reach.
DJI Goggles 3 × 1
DJI Goggles 3 -2.0D Corrective Lenses (Pair) × 1
USB-C OTG Cable × 1
DJI Avata 2
DJI Mini 4 Pro
DJI Air 3
DJI O4 Air Unit Pro
DJI O4 Air Unit
DJI O3 Air Unit
* The screen refresh rate changes with the video transmission frame rate. It may switch between 100 Hz and 60 Hz to adapt to the current video transmission frame rate.
** The 3-hour max operating time was measured at an ambient temperature of 25° C (77° F), screen brightness at 4, connected to the DJI Avata 2 aircraft, video transmission set to 1080p/100fps, Head Tracking off, Real View off, and the goggles' battery fully charged and not supplying power to external devices such as smartphones.
*** Some countries and regions prohibit the use of the 5.1GHz or 5.8GHz frequency band, or both. In some countries and regions, the 5.1GHz frequency is only allowed for indoor use. If the 5.1GHz/5.8GHz frequency bands are not available (such as in Japan), screen sharing to the smartphone via Wi-Fi is not available. To achieve this function, a wired connection is recommended. Before flying, make sure to check and comply with local radio and aviation laws and regulations.
We Value Your Privacy
Cookie Preferences
