bannerimg
Deliver to
Estimated shipping date: Apr. 21, expected arrival date: Apr. 23
USD $229
Embrace the Pilot's Perspective
When paired with DJI Neo/DJI Avata 2 and DJI RC Motion 3, [1] DJI Goggles N3 lets you soar through the skies and enjoy an immersive flight experience, as if you were in the pilot seat. Activate the head tracking function to control Neo/Avata 2 with head or wrist movements, achieving seamless synergy.
Ready to Use, Streamlined Creation
Roomy and Eyewear-Friendly Design: The roomy interior comfortably accommodates glasses, without needing diopter adjustments or lens installations. Simply put them on, and you can take off right away.
Integrated Design: The integrated headband and battery design balance the overall weight of the goggles, ensuring no pressure on your face for a comfortable fit.
One-Tap Defogging: When fog builds up on the surface of the lenses, the defogging function effectively controls moisture by accelerating the internal fan speed to swiftly circulate air, making it ideal for changing temperatures and high-humidity conditions.
1080p Ultra-Wide Screen
DJI Goggles N3 has a full 1080p screen and an impressive 54° FOV. Enjoy stunning visuals as impactful aerial scenes come alive before your eyes.
O4 FHD Video Transmission
The advanced DJI O4 digital video transmission system adopts the same antenna design as Goggles 2, offering exceptional anti-interference performance. Enjoy 1080p/60fps live feeds with a minimum latency of 31 ms [2] and a transmission range of up to 13 km. [3] The goggles automatically select the optimal frequency band between 2.4 GHz and 5.8 GHz [4] based on the environment. This ensures stable transmission so you can experience flying in real-time and get a buttery-smooth live view.
With a max video transmission bitrate of 60 Mbps [5] and SyncSmooth technology, video transmission from the skies to the ground is optimized, providing a smooth live view even when flying at a high speed.
AR Cursor
DJI RC Motion 3 [1] can be used as an AR cursor before the aircraft takes off, or when the aircraft is hovering after braking. This allows you to effortlessly activate functions and adjust settings without taking your hands off RC Motion 3.
2.7-Hour Operating Time
A fully charged DJI Goggles N3 can last through the use of up to 13 DJI Neo batteries. [6] With a powerful 2.7-hour operating time, [7] you can unleash your creative passion and potential to the fullest.
DJI Goggles N3 × 1
DJI Avata 2
DJI O4 Air Unit Pro
DJI O4 Air Unit
1. DJI Neo, DJI Avata 2, and DJI RC Motion 3 are sold separately.
2. Measured when paired with DJI Avata 2, using 1080p/100fps video transmission, and in an open outdoor environment without interference. The 58ms minimum latency was measured when paired with DJI Neo, using 1080p/60fps video transmission, and in an open outdoor environment without interference.
3. Measured when paired with DJI Avata 2, compliant with FCC standards, in an open outdoor environment without interference, and subject to the aircraft's max flight distance. Under the same test conditions, when paired with DJI Neo, the transmission distance is 10 km (FCC) and 6 km (CE/SRRC/MIC).
4. The 5.8 GHz frequency band is currently banned in certain countries/regions. Always check and strictly abide by local laws and regulations before flying.
5. Measured when paired with DJI Avata 2 in an open environment without interference. The video transmission bitrate varies by operating environment. Under the same test conditions, the max bitrate is 50 Mbps when paired with DJI Neo.
6. Measured with DJI Neo paired with DJI RC Motion 3 during steady flight at constant speed in Normal mode.
7. The 2.7-hour max operating time was measured at an ambient temperature of 25° C, screen brightness at 6, connected to the DJI Avata 2 aircraft, video transmission set to 1080p/100fps, Head Tracking off, and the goggles' battery fully charged and not supplying power to external devices such as smartphones.
We Value Your Privacy
Cookie Preferences
