bannerimg
Deliver to
Estimated shipping date: Apr. 1, expected arrival date: Apr. 3
USD $718USD $1,021
DJI Power 1000
The robust DJI Power 1000 provides stable power supply to more than 99% of common household devices. It has a battery capacity of 1024 Wh, providing a max output power of 2600W, and can fast charge DJI Inspire 3 batteries. DJI Power SDC to DJI Inspire 3 Fast Charge Cable has a fast charging power of 200 W. It can charge an Inspire 3 TB51 Intelligent Battery from 0% to 100% in approx. 44 minutes, and from 10% to 95% in about 28 minutes.
If you use the standard mode of the TB51 Intelligent Battery Charging Hub to charge the battery, charging from 0% to 100% takes about 55 minutes.
Tips
After a flight, the battery temperature may be high and potentially outside the permissible temperature range for immediate charging. In such cases, it is recommended to wait until the battery temperature drops below 40° C (104° F) before initiating a charge.
DJI Power 1000
DJI Power AC Power Cable ×1
DJI Power SDC to DJI Inspire 3 Fast Charge Cable × 1
DJI Power 1000:
Capacity: 1024 Wh
Weight: Approx. 13 kg
Dimensions: 448×225×230 mm (L×W×H)
AC Output:
DYM1000L: AC 100-120 V, 50/60 Hz, max continuous output: 2200 W,* max output: 2600 W (total),** peak output: 4400 W
DYM1000H: AC 220-240 V, 50/60 Hz, max continuous output: 2200 W,* max output: 2600 W (total),** peak output: 4400 W
* At a room temperature of 25° C (77° F), Power 1000 can stably provide a max continuous output of 2200 W until the battery runs out. Data measured in a DJI laboratory.
** At an output power of 2600 W, the DYM1000L prototype can sustain for 30 seconds, and the DYM1000H prototype can sustain for 60 seconds. Durations were measured when DJI Power 1000 is at approx. 25° C (77° F) and 50% battery level. Duration may vary due to differences in battery temperature and battery level. Refer to the actual usage. It is recommended to use max power output when the battery is at a moderate temperature and a relatively higher battery level. Data measured in a DJI laboratory.
DJI Power SDC to DJI Inspire 3 Fast Charge Cable Length: 40 cm
DJI Inspire 3
We Value Your Privacy
Cookie Preferences
