bannerimg
Deliver to
Estimated shipping date: Apr. 1, expected arrival date: Apr. 3
USD $398USD $521
DJI Power 500
DJI Power 500 has a battery capacity of 512 Wh to provide a max output power of 1000 W, and can fast charge DJI Inspire 3 batteries. DJI Power SDC to DJI Inspire 3 Fast Charge Cable has a fast charging power of 200 W. It can charge an Inspire 3 TB51 Intelligent Battery from 0% to 100% in approx. 44 minutes, and from 10% to 95% in about 28 minutes.
If you use the standard mode of the TB51 Intelligent Battery Charging Hub to charge the battery, charging from 0% to 100% takes about 55 minutes.
Tips
After a flight, the battery temperature may be high and potentially outside the permissible temperature range for immediate charging. In such cases, it is recommended to wait until the battery temperature drops below 40° C (104° F) before initiating a charge.
DJI Power 500
DJI Power AC Power Cable ×1
DJI Power SDC to DJI Inspire 3 Fast Charge Cable × 1
DJI Power 500:
Capacity: 512 Wh
Weight: Approx. 7.3 kg
Dimensions: 305×207×177 mm (L×W×H)
AC Output:
DYM500H: AC 220-240 V, 50/60 Hz, rated: 800 W, max continuous output: 1000 W
* Max continuous output power is available when the product's battery level is above 20%. AC output data varies by country and region.
DJI Power SDC to DJI Inspire 3 Fast Charge Cable Length: 40 cm
DJI Inspire 3
We Value Your Privacy
Cookie Preferences
