DJI Mavic 3 Enterprise Series Battery Kit includes three Intelligent Flight Batteries and one DJI Mavic 3 Battery Charging Hub (100W) to meet the needs of long-duration operations.
Highlights
Includes three Intelligent Flight Batteries and one DJI Mavic 3 Battery Charging Hub (100W) to meet the needs for long-duration operations.
Tips
1. It is recommended to use the DJI USB-C Power Adapter (100W) to provide power supply for the DJI Mavic 3 Battery Charging Hub (100W).
2. The charging hub is only compatible with BWX260-5000-15.4 Intelligent Flight Batteries. DO NOT attempt to use the charging hub with other battery models.
3. Place the charging hub on a flat and stable surface when in use. Make sure the device is properly insulated to prevent fire hazards.
4. DO NOT attempt to touch the metal terminals on the battery case.
5. Clean the metal terminals on the battery case with a clean, dry cloth if there is any noticeable buildup.
DJI Mavic 3 Intelligent Flight Battery × 3
DJI Mavic 3 Battery Charging Hub (100W) × 1
Intelligent Flight Battery:
Model: BWX260-5000-15.4
Capacity: 5000 mAh
Weight: 335.5 g
Battery Type: LiPo 4S
Charging Temperature: 5° to 40° C (41° to 104° F)
DJI Mavic 3 Battery Charging Hub (100W):
Model: CHX265-100
Dimensions: 150×55×28 mm (L×W×H)
Weight: 116 g
Operating Temperature: 5° to 40° C (41° to 104° F)
Input: 5-20 V, max 5 A
Compatible Power Adapter: DJI USB-C Power Adapter (100W)
Charging Time: Approx. 1 h 10 mins (single battery)*
* Tested using the DJI USB-C Power Adapter (100W).
DJI Mavic 3 Enterprise Series aircraft
