DJI 100W USB-C Power Adapter
Region
Out of Stock
With two USB-C output ports, it can fast charge the Intelligent Flight Battery and a remote controller at the same time. It also supports PPS and PD protocols to fast charge mobile devices with a USB-C port.
Charge DJI Mavic 3 Enterprise series aircraft, DJI RC Pro Enterprise remote controller, or mobile devices with a USB-C port using a power outlet.
1. DO NOT attempt to touch the metal terminals on the battery case.
2. Clean the metal terminals on the battery case with a clean, dry cloth if there is any noticeable buildup.
3. The charger varies in different regions. Plugs for different regions are available for purchase on the DJI online store.
DJI 100W USB-C Power Adapter × 1
Input Voltage: 100-240 V (AC), 50-60 Hz, 2.5 A
Output Power: 100 W (When both ports are used, the maximum output power of each port is 82 W, and the charger will dynamically allocate the output power of the two ports according to the power load.)
Operating Temperature: 5° to 40° C (41° to 104° F)
Charging Time*:
DJI Mavic 3 Intelligent Flight Battery: approx. 1 hour and 10 mins
DJI RC-N1: approx. 2 hours and 40 mins
DJI RC: approx. 2 hours
DJI RC Pro: approx. 2 hours
DJI RC Pro Enterprise: approx. 1 hour and 30 mins
DJI Avata Intelligent Flight Battery: approx. 47 mins
DJI Goggles 2 Battery: approx. 1 hour and 50 mins
* Devices will take longer to charge if both ports are used for charging simultaneously. Tested in a lab environment and should be taken as reference only.
DJI Mavic 3 Pro
DJI Mavic 3 Pro Cine
DJI Mavic 3 Classic
DJI Mavic 3
DJI Mavic 3 Cine
DJI Mavic 3 Enterprise Series
