DJI Mavic 3
  • A Camera for Capturing the Best
    The 4/3 CMOS Hasselblad camera can effectively suppress noise in low-light environments, delivering higher resolution and dynamic range.
  • Tele Camera For Unique Shots
    The tele camera can be used to frame shots or explore. Whether capturing landscapes or people, enjoy more flexibility and creative potential.
  • Extended Flight Time to See More
    Up to 46 minutes of flight time [1] lets you plan flight routes, compose your shots, and capture it all with ease.
  • Upgraded Transmission System
    The upgraded O3+ transmission system enables a 15km* max transmission range and a 1080p/60fps [2] live feed for smooth, stable flights.
  • Fly with Intelligent Safety
    With omnidirectional obstacle sensing, Mavic 3 can detect obstacles in all directions and plan a safe flight route. [3]
  • A Pro Codec for Pro Creation
    Mavic 3 Cine supports Apple ProRes 422 HQ, Apple ProRes 422, and Apple ProRes 422 LT [4] encoding and has a built-in 1TB SSD, [5] facilitating professional creation in every way.
  • DJI Mavic 3
    DJI Mavic 3
  • DJI RC-N1 Remote Controller
  • Spare DJI RC-N1 Control Sticks (Pair)
  • DJI RC-N1 RC Cable (USB-C Connector)
  • DJI RC-N1 RC Cable (Lightning Connector)
  • DJI RC-N1 RC Cable (Standard Micro-USB Connector)
  • DJI Mavic 3 Intelligent Flight Battery
    × 3
  • DJI Mavic 3 Low-Noise Propellers (pair)
    × 6
  • DJI 65W Portable Charger
  • DJI Mavic 3 Storage Cover
  • USB-C Cable
    USB-C Cable
  • DJI Mavic 3 Battery Charging Hub
  • DJI Convertible Carrying Bag
  • DJI Mavic 3 ND Filters Set (ND4/8/16/32)
Moments by You
DJI Mavic 3
DJI Mavic 3 Classic
DJI Mavic 3 Cine
DJI Mavic 3
DJI Mavic 3 Classic (DJI RC-N1)
DJI Mavic 3 Cine Premium Combo
DJI Mavic 3
DJI Mavic 3 Classic
DJI Mavic 3 Cine
Flagship
Flagship
Flagship
Dual-Lens Flagship Camera Drone
Flagship Camera Drone With Hasselblad Camera
Flagship camera drone for pros
From USD $2,049
From USD $1,279
From USD $4,999
Highlights
895 gWeight
895 gWeight
899 gWeight
46 minsMax Flight Time
DJI RC-N1Standard Remote Controller
RC ProRemote Controller
8 GBInternal Storage
1 TB SSDInternal Storage
Image Quality
img4/3 CMOS Hasselblad Camera
1/2-inch CMOS Tele Camera
f/2.8-f/11Adjustable Aperture
20 MPPixels
20 MPPixels
20 MPPixels
5.1KHasselblad Camera: 5.1K/50fps、DCI 4K/120fps
Tele Camera: 4K/50fps
5.1K5.1K/50fps
DCI 4K/120fps
5.1K5.1K/50fps
DCI 4K/120fps
Apple ProRes 422 HQ/422/422 LT
Safety & Flight Performance
imgOmnidirectional Obstacle Sensing
imgDJI O3+ 15km,
1080p/60fps Transmission
imgDJI O3+ 15km,
imgDJI O3+ 15km,
[1] Measured with Mavic 3 flying at a constant speed of 32.4 kph in a windless environment at sea level until the battery reached 0%. Data is for reference only. Please pay attention to the RTH reminder on the DJI Fly app during flight.
[2] Unobstructed and free of interference. Actual resolution may vary depending on the quality of the transmission signal.
[3] DO NOT use the aircraft in severe weather conditions including heavy wind exceeding 13.8 m/s, snow, rain, fog, hail, or lightning. DO NOT fly the aircraft 6,000 m (19,685 ft.) or higher above sea level. DO NOT fly the aircraft in environments where the temperature is below -10° C (14° F) or above 40° C (104° F). DO NOT take off from moving objects such as cars or boats. DO NOT fly close to reflective surfaces such as water or snow. Otherwise, the vision system may be limited. When the GNSS signal is weak, fly the aircraft in environments with good lighting and visibility. Low ambient light may cause the vision system to function abnormally. DO NOT fly near areas with magnetic or radio interference. Common source of magnetic or radio interference interferece includes Wi-Fi hotspots, routers, Bluetooth devices, high-voltage lines, large-scale power transmission stations, radar stations, mobile base stations, and broadcasting towers. Be careful when taking off in desert or beach areas to avoid sand entering the aircraft. Fly the aircraft in open areas. Buildings, mountains, and trees may block the GNSS signal and affect the on-board compass.
[4] DJI Mavic 3 Cine supports Apple ProRes 422 HQ and H.264/H.265 encoding, while Mavic 3 only supports H.264/H.265 encoding.
[5] Actual available storage space may be reduced due to system configuration. For more details, see the Mavic 3 specs.
[6] ActiveTrack is not available at video resolutions higher than 4K or frame rates over 60fps.
