bannerimg
Deliver to
Estimated shipping date: Mar. 28, expected arrival date: Apr. 3
USD $649
DJI Mavic 3 Classic
The DJI Mavic 3 Fly More Kit includes two Intelligent Flight Batteries, a 100W Battery Charging Hub, a 65W Car Charger, a Convertible Carrying Bag, and Low-Noise Propellers, providing comprehensive support for your aerial photography experience at a better price than buying these items separately.
1. Intelligent Flight Battery: One Intelligent Flight Battery provides a 46-min* max flight time, allowing you to explore more of your surroundings and fly with greater peace of mind.
2. 100W Battery Charging Hub: Expands the charging interface to three. The battery charging hub enhances efficiency by charging batteries in sequence according to their remaining power level, with more fully-charged batteries receiving power first.
3. 65W Car Charger: A must-have on the go, the 65W Car Charger can charge different devices in the car. It provides a stable output power of 65 W and two output ports (USB-C and USB-A) for charging the Intelligent Flight Battery and remote controller at the same time. It also supports PPS and PD protocols to charge your smartphone, laptop, and other devices.
4. Low-Noise Propellers: Each propeller blade has been put under precise dynamic balancing tests to increase aerodynamic efficiency and output less noise.
5. Convertible Carrying Bag: This well-designed bag can be used as either a shoulder bag or a backpack to meet your needs for short trips.
Tips
* Measured by Mavic 3 Classic flying at a constant speed of 32.4 kph in a windless environment at sea level until the battery reached 0%. Data is for reference only.
DJI Mavic 3 Intelligent Flight Battery × 2
DJI Mavic 3 100W Battery Charging Hub × 1
DJI 65W Car Charger × 1
DJI Mavic 3 Low-Noise Propellers (pair) × 3
DJI Convertible Carrying Bag × 1
Weight: 1780 g
Dimensions (Single-strap mode): 33×17.5×28 cm (L×W×H)
Dimensions (Double-strap mode): 33×17.5×53 cm (L×W×H)
DJI Mavic 3 Pro
DJI Mavic 3 Pro Cine
DJI Mavic 3 Classic
DJI Mavic 3
DJI Mavic 3 Cine
We Value Your Privacy
Cookie Preferences
