DJI Mavic 3 Pro (DJI RC)
Select Option
Flagship Tri-Camera System
With a 4/3 CMOS Hasselblad camera, a 70mm tele camera, and a 166mm tele camera, Mavic 3 Pro helps you create stunning works in various scenarios.
4/3 CMOS Hasselblad Camera
The Hasselblad camera shoots 5.1K/50fps and 4K/120fps [1] with a f/2.8 - f/11 range. The 10-bit D-Log M mode records up to one billion colors.
Apple ProRes for Pro Creation
Mavic 3 Pro Cine has triple camera Apple ProRes codec support. It also has a built-in 1TB SSD [2] and a 10Gbps lightspeed data cable.
![43-Min Max Flight Time [3]](//se-cdn.djiits.com/tpc/uploads/core_selling_point/image/a8062f369fa8d033c2187febea013473@origin.jpg)
Mavic 3 Pro gives you more confidence to fly further while enjoying aerial photography creation. Execute every step during a single flight.
![Omnidirectional Obstacle Sensing [4]](//se-cdn.djiits.com/tpc/uploads/core_selling_point/image/8d8c6b20a30b8300b27850c9405d988c@origin.jpg)
Mavic 3 Pro allows you to fly even in complex environments. Eight sensors and powerful computing engine sense obstacles and plan a safe route.
![15km HD Video Transmission [5]](//se-cdn.djiits.com/tpc/uploads/core_selling_point/image/e82da02267e063fb05a196c21c9bda19@origin.jpg)
DJI O3+ supports a transmission distance of up to 15 km and 1080p/60fps live feed, for smoother control.
Thrilling Immersive Flight
DJI Mavic 3 Pro
DJI RC
DJI Mavic 3 Series Intelligent Flight Battery
DJI Mavic 3 Series Low-Noise Propellers (Pair)
× 3
DJI 65W Portable Charger
USB 3.0 Type-C Cable
DJI Mavic 3 Pro Storage Cover
DJI RC Spare Control Sticks (pair)
Moments By You
Understand the Triple-Camera Imaging System With One Picture
Is it necessary to upgrade to the Mavic 3 Pro Series if I already have a Mavic 3 or Mavic 3 Classic?
What are some use cases for the new 70mm medium tele camera of the Mavic 3 Pro Series?
What are the advantages of the 166mm tele camera?
What differentiates Mavic 3 Pro Cine from Mavic 3 Pro? How should I choose?
What are the differences between DJI RC and DJI RC Pro? How should I choose?
Is the Fly More Combo worth buying?
Does the DJI Mavic 3 Series support the DJI Goggles Series and the DJI Motion Controller Series?
What precautions should be taken when using DJI Goggles Integra / DJI Goggles 2 with the DJI Mavic Series or DJI Mini Series for the first time?
Does the DJI RC-N1 remote controller support the O3+ video transmission when used with the DJI Mavic 3 Series aircraft?
Is the DJI Mavic 3 Pro Series compatible with accessories of DJI Mavic 3 or DJI Mavic 3 Classic?
1. ActiveTrack is unavailable at video resolutions higher than 4K or frame rates over 60fps.
2. Actual available storage space may be reduced due to system configuration. For details, please refer to the Specs page of Mavic 3 Pro on the official DJI website.
3. Flight Time was measured with Mavic 3 Pro flying at a constant speed of 32.4 kph in a windless environment at sea level until the battery level reached 0%. Data is for reference only. Please pay attention to RTH reminders in the DJI Fly app during your flight.
4. DO NOT use the aircraft in severe weather conditions, including heavy wind exceeding 12 m/s, snow, rain, fog, hail, or lightning. DO NOT fly the aircraft 6000 m (19685 ft.) or higher above sea level. DO NOT fly the aircraft in environments where the temperature is below -10° C (14° F) or above 40° C (104° F). DO NOT take off from moving objects such as cars or boats. DO NOT fly close to reflective surfaces such as water or snow. Otherwise, the vision system may not work correctly. When the GNSS signal is weak, fly the aircraft in environments with good lighting and visibility. Low ambient light may cause the vision system to function abnormally. DO NOT fly near areas with magnetic or radio interference. Familiar magnetic or radio interference sources include Wi-Fi hotspots, routers, Bluetooth devices, high-voltage lines, large-scale power transmission stations, radar stations, mobile base stations, and broadcasting towers. Avoid sand entering the aircraft when taking off in desert or beach areas. Fly the aircraft in open areas away from crowds. Buildings, mountains, and trees may block the GNSS signal and affect the onboard compass.
5. Measured in an outdoor, open environment, without interference, and with FCC compliance. The above data shows the farthest communication range for one-way, non-return flights. Please pay attention to RTH reminders in the DJI Fly app during your flight.
![43-Min Max Flight Time [3]](http://se-cdn.djiits.com/tpc/uploads/core_selling_point/image/a8062f369fa8d033c2187febea013473@origin.jpg)
![Omnidirectional Obstacle Sensing [4]](http://se-cdn.djiits.com/tpc/uploads/core_selling_point/image/8d8c6b20a30b8300b27850c9405d988c@origin.jpg)
![15km HD Video Transmission [5]](http://se-cdn.djiits.com/tpc/uploads/core_selling_point/image/e82da02267e063fb05a196c21c9bda19@origin.jpg)
