bannerimg
Deliver to
Estimated shipping date: Apr. 15, expected arrival date: Apr. 19
USD $398USD $521
DJI Power 500
It has a battery capacity of 512 Wh to provide a max output power of 1000 W, and can fast charge select DJI drone batteries. DJI Power SDC to DJI Mavic 3 Series Fast Charge Cable
has a fast charging power of 150 W. It can charge a DJI Mavic 3 Series Intelligent Flight Battery from 0% to 100% in approx. 58 minutes, and from 10% to 95% in about 32 minutes.
With DJI 65W Portable Charger, it takes approx. 96 minutes to charge the battery from 0% to 100%. When using the DJI 100W USB-C Power Adapter in conjunction with the DJI Mavic 3 Series 100W Battery Charging Hub, it takes approx. 70 minutes to charge from 0% to 100%.
Tips
After a flight, the battery temperature may be high and potentially outside the permissible temperature range for immediate charging. In such cases, it is recommended to wait until the battery temperature drops below 40° C (104° F) before initiating a charge.
*Actual appearance of certain accessories may vary.
DJI Power 500 × 1
DJI Power AC Power Cable × 1
DJI Power SDC to DJI Mavic 3 Series Fast Charge Cable × 1
DJI Power 500:
Capacity: 512 Wh
Weight: Approx. 7.3 kg
Dimensions: 305×207×177 mm (L×W×H)
AC Output:
DYM500H: AC 220-240 V, 50/60 Hz, rated: 800 W, max continuous output: 1000 W
* Max continuous output power is available when the product's battery level is above 20%. AC output data varies by country and region.
DJI Power SDC to DJI Mavic 3 Series Fast Charge Cable Length: 40 cm
DJI Mavic 3 series
DJI Mavic 3 Classic
DJI Mavic 3 Pro Series
DJI Mavic 3 Enterprise Series
DJI Mavic 3 Multispectral Edition
We Value Your Privacy
Cookie Preferences
