Deliver to
Free express shipping arrival date: Apr. 14
USD $108
DJI Mic Mini
  • Small, Ultralight, Discreet
  • High-Quality Audio With Stable Transmission
  • 48-Hour Operation w/ Case [3]
  • DJI OsmoAudio™ Direct Connection for Premium Sound Quality [5]
    The transmitter supports direct Bluetooth connection to Osmo Action 5 Pro, Osmo Action 4, or Osmo Pocket 3 without a receiver, simplifying your gear and workflow.
  • Two-Level Active Noise Cancelling
  • Automatic Limiting to Prevent Audio Clipping [7]
  • DJI Mic Mini Transmitter (Infinity Black)
  • DJI Mic Mini Receiver
  • DJI Mic Mini Camera Audio Cable (3.5mm TRS)
  • DJI Mic Mini Mobile Phone Adapter (Type-C)
  • DJI Mic Mini Windscreen (Black/Gray)
  • DJI Mic Mini Windscreen (Black)
  • DJI Mic Mini Clip Magnet
  • DJI Mic Mini Compact Carrying Pouch
  • DJI Mic Splitter Charging Cable
  • DJI Mic Mini Transmitter Charging Dock (Infinity Black)
  • DJI Mic Mini Mobile Phone Adapter (Lightning)
DJI Mic Mini
DJI Mic 2
DJI Mic Mini (1 TX + 1 RX)
DJI Mic 2 (2 TX + 1 RX + Charging Case)
DJI Mic (2 TX + 1 RX + Charging Case)
DJI Mic Mini
DJI Mic 2
Mini Wireless Microphone
Wireless Microphone for Pro-Level Audio
Compact Magnetic Wireless Microphone
From USD $89
From USD $219
From USD $159
10 gTransmitter Weight
28 gTransmitter Weight
30 gTransmitter Weight
imgTwo-level noise cancelling
imgIntelligent noise cancelling
SupportedAutomatic Limiting to Prevent Audio Clipping
img14 hours, supporting 32-bit float internal recording
img14-hour internal recording
48 hoursTotal Operating Time
18 hoursTotal Operating Time
15 hoursTotal Operating Time
imgDirectly connect to Osmo Action 5 Pro, Osmo Action 4, or Osmo Pocket 3 via DJI OsmoAudio™
imgDirectly connect to Osmo Action 5 Pro, Osmo Action 4 or Osmo Pocket 3 via DJI OsmoAudio™
imgBoth Lightning and USB-C adapters support digital audio and playback without unplugging the receiver; direct Bluetooth connection with phone
imgLightning (analog) or USB-C (digital audio supports Stereo) adapter.
img3.5mm TRS cable
RX auto power-on/off in sync with the camera
img3.5mm TRS cable
img3.5mm TRS cable
imgUSB-C
imgUSB-C
imgUSB-C
imgDial + buttons
img1.1-inch touchscreen + dial
img0.95-inch touchscreen
imgDJI Lavalier Mic
Camera Adapter
imgDJI Lavalier Mic
5. DJI Mic Mini transmitters can directly connect to select DJI products (one TX for Osmo Action 4, up to two TX for Osmo Pocket 3 and Osmo Action 5 Pro). The transmitter's operating time is approx. 7 to 8 hours when directly connected. More DJI products will be supported in the future.
6. Strong and Basic noise cancellation levels can be set via the DJI Mimo app, or directly on the product interface when using an Osmo Action 5 Pro, Osmo Action 4, or Osmo Pocket 3 connected to one or more transmitters via DJI OsmoAudio™ Direct Connection. When the transmitter directly connects to a smartphone, the noise cancellation level cannot be adjusted in the Mimo app; it defaults to the Strong setting.
7. When the transmitter is used with the receiver, automatic limiting is enabled by default and can be turned on or off via the DJI Mimo app; when the transmitter is connected directly to a smartphone via Bluetooth, this feature is enabled by default and cannot be turned off. The feature can also be turned on or off directly on the product interface when using an Osmo Action 5 Pro, Osmo Action 4, or Osmo Pocket 3 connected to one or more transmitters via DJI OsmoAudio™ Direct Connection.
We Value Your Privacy
Cookie Preferences
