DJI Mini 3 Pro
Be prepared and fly freely with peace of mind with 34 mins of max flight time with DJI Mini 3 Pro; 38 mins of max flight time with DJI Mini 3.
Tips
* Measured at a constant speed of 21.6 kph in windless conditions.
Intelligent Flight Battery × 1
Model: BWX162-2453-7.38
Capacity: 2453 mAh
Weight: Approx. 80.5 g
Voltage: 7.38 V
Charging Voltage Limit: 8.5 V
Battery Type: Li-ion
Energy: 18.1 Wh
Max Charging Power: 37 W
Charging Time: 64 mins (with DJI 30W USB-C Charger and the battery mounted to the aircraft)
Charging Temperature: 5° to 40° C (41° to 104° F)
Recommended Charger: DJI 30W USB-C Charger or other USB Power Delivery chargers.
DJI Mini 4 Pro*
DJI Mini 3 Pro
DJI Mini 3
* When using the DJI Mini 3 Series Intelligent Flight Battery, DJI Mini 4 Pro’s propulsion performance and flight time will be reduced, and the total weight will exceed 249 g. Always check local laws and regulations before use.
