DJI Mini 4 Pro/Mini 3 Pro Propellers
AUD $19
Propellers specially made for DJI Mini 3 Pro produce less noise and provide higher aerodynamic efficiency and powerful thrust to the aircraft.
Propellers specially made for DJI Mini 4 Pro/Mini 3 Pro produce less noise and have undergone precise dynamic balancing tests to provide higher aerodynamic efficiency and powerful thrust to the aircraft.
Tips
Follow the instructions and attach propellers to the correct frame arms.
When changing propellers, use the propellers in the same package. Do not mix propellers from different packages.
Propellers (pair) × 2
Screws × 12
Diameter × Thread Pitch: 6.0 × 3.0 inch
Weight (each): 0.9 g
DJI Mini 4 Pro
DJI Mini 3 Pro
