bannerimg
Deliver to
Expected arrival date: May 14
USD $479
Refurbished Products
  • Lightweight & Hassle-Free
    At sub 249 g [1], Mini 3 Pro doesn't require registration in most countries. The foldable design also makes it easy to carry and store.
  • Sweet Air Time
    The standard Intelligent Flight Battery provides up to 34 minutes of battery life, enough power to cover your aerial photography needs. [5]
  • Next Level Safety
    With forward, backward, and downward vision sensors, ToF, and APAS 4.0 [2], Mini 3 Pro can avoid obstacles, even in complicated environments.
  • Pro, and We Mean It
    Mini 3 Pro records video at up to 4K/60fps. The 1/1.3-inch sensor features dual-native ISO and supports the direct output of HDR footage. [3]
  • Intelligent Features in a Tap
    Take your creations to new heights with powerful storytelling tools like FocusTrack [4], MasterShots, and Timelapse.
  • DJI Mini 3 Pro
    DJI Mini 3 Pro
  • DJI RC-N1 Remote Controller
  • DJI RC-N1 RC Cable (USB Type-C Connector)
  • DJI RC-N1 RC Cable (Lightning Connector)
  • DJI RC-N1 RC Cable (Standard Micro-USB Connector)
  • DJI Mini 3 Pro Intelligent Flight Battery
  • Spare Propellers (Pair)
  • Gimbal Protector**
    Gimbal Protector**
  • Type-C to Type-C PD Cable
  • Screwdriver
    Screwdriver
  • Screws
    Screws
    × 6
DJI Mini 3 Pro does not come with a power adapter. You can use your own USB-C power adapter. It is recommended to use the DJI 30W USB-C Charger (sold separately) or other USB Power Delivery chargers.
** The above figure is for reference only. Due to different production batches, DJI provides two kinds of gimbal protectors that are slightly different in appearance. The two gimbal protectors have the same function and can be used in the same way.
1. Standard aircraft weight (including DJI Mini 3 Pro Intelligent Flight Battery, propellers, and a microSD card). The actual product weight may vary due to differences in batch materials and external factors. Registration is not required in some countries and regions. Check local rules and regulations before use.
2. APAS 4.0 is not available while recording 4K/48fps, 4K/50fps, 4K/60fps, 2.7K/48fps, 2.7K/50fps, 2.7K/60fps and 1080p/120fps video.
3. HDR video does not support video recording at over 30fps.
4. FocusTrack is not available while recording 4K/48fps, 4K/50fps, 4K/60fps, 2.7K/48fps, 2.7K/50fps, 2.7K/60fps, 1080p/48fps, 1080p/50fps, 1080p/60fps, and 1080p/120fps video.
5. Measured at a constant speed of 21.6 kph in windless conditions.
We Value Your Privacy
Cookie Preferences
