DJI Mini 4 Pro Fly More Combo Plus (DJI RC 2)
Select Option
Don't Miss Top Accessories
Take it. Easy.
Weighing less than 249 g, [1] Mini 4 Pro was designed for life on the go. There's no need for training or examinations in most countries and regions.
Fly Longer, Create More
Stay focused on creation with two battery options. Enjoy up to 34 or 45 minutess flight time of flight time depending on your needs. [2]
Out-Sized Imaging Performance
Equipped with a 1/1.3" CMOS sensor, it supports 4K/60fps HDR True Vertical Shooting. With 10-bit D-Log M/HLG color modes, record up to one billion colors.
Stable, Reliable Video Transmission
The drone features DJI’s O4 video transmission. Enjoy smooth 1080p/60fps live feeds from up to 20 km. [3]
Sense More, Fly Safe
The first product of the Mini Series that can flexibly avoid and detect obstacles sooner with omni sensing. Even new pilots can fly worry-free.
A Touch of Cinematics
Experience ActiveTrack 360° and tailor multiple tracking routes to fit any shooting scenario. Pro-level results are simple now.
DJI Mini 4 Pro
DJI RC 2 Remote Controller
Intelligent Flight Battery Plus
× 3
Two-Way Charging Hub
Shoulder Bag
USB-C Cable
Spare Propellers (Pair)
× 3
Screws
× 18
Screwdriver
Type-C to Type-C PD Cable
Gimbal Protector
Propeller Holder
Moments By You
Compared with DJI Mini 3 Pro, what has been upgraded on DJI Mini 4 Pro?
DJI Mini 4 Pro features comprehensive upgrades in its vision sensing system, imaging system, video transmission system, and intelligent features.
Details are as follows: While maintaining a 249g lightweight design, DJI Mini 4 Pro boasts an omnidirectional vision sensing system to achieve omnidirectional obstacle sensing. It uses a new image-processing platform and supports recording 4K/60fps HDR videos, with optional 10-bit D-Log M and HLG color modes, elevating multiple shooting specifications. It is equipped with the DJI O4 FHD digital video transmission system, which provides a max transmission distance of up to 20 km*. It comes with the newly upgraded ActiveTrack 360°, Waypoint Flight, Advanced RTH, Cruise Control, and other intelligent features.
Data tested under FCC standard in an unobstructed environment without interference. Used for reference purposes only and provides no guarantee for actual transmission distance.
Compared with DJI Mini 3 Pro, what are the upgrades in the camera module of DJI Mini 4 Pro?
Compared with the camera module of DJI Mini 3 Pro, DJI Mini 4 Pro has the following major upgrades:
1. A new image-processing platform is used to improve the overall imaging performance.
2. The HDR video specification has been upgraded from 4K/30fps to 4K/60fps.
3. The Slow Motion specification has been upgraded from 1080p to 4K.
4. The new 10-bit D-Log M and HLG color modes record colors and details with a high dynamic range.
5. The new Night video mode (Night Shots) delivers enhanced low-light performance.
6. The simulated long exposure (shutter speed of up to 8 s) enables more creative possibilities.
7. A next-gen SmartPhoto algorithm is adopted to effectively improve photo quality.
8. The resolution of panorama photos is higher.
Compared with the O3 video transmission system, what are the upgrades of the O4 video transmission system?
The O4 video transmission system adopts an all-new hardware solution, and a new frequency band* has been added. The communication algorithm has also been upgraded, which not only delivers an FHD video transmission from a max range of 20 km**, but also features enhanced anti-interference capabilities, further improving the transmission stability in complex environments like urban settings. The remote controller also supports a 1080p/60fps max real-time live feed, with the higher frame rate delivering a smoother viewing experience.
* Can be used only in countries and regions where it is allowed by local laws and regulations.
** Measured in an outdoor, open environment, without interference, and with FCC compliance. The above data shows the farthest communication range for one-way, non-return flights. Always pay attention to reminders in the app during your flight.
Compared with DJI RC-N2, what are the advantages of DJI RC 2? How should I choose?
When using DJI RC-N2, you need to connect your smartphone and download the DJI Fly app. DJI RC 2 comes with a 5.5-inch 1080p FHD screen with a brightness of up to 700 nits, delivering a better outdoor viewing experience. Additionally, with the DJI Fly app pre-installed, you can enjoy immediate use after powering on without connecting to your smartphone, facilitating concentrated and efficient creation.
Compared with DJI RC-N1, what are the upgrades of DJI RC-N2?
The video transmission solution has been upgraded, and the antenna system has been upgraded from 1T2R to 2T2R. With DJI Mini 4 Pro, the O4 video transmission can be used.
Compared with DJI RC, what are the upgrades of DJI RC 2?
The performance of the processor has been improved for smoother operation. The video transmission solution has been upgraded, and the antenna system has been upgraded from 1T2R to 2T4R. With DJI Mini 4 Pro, the O4 video transmission can be used. DJI RC 2 features two built-in antennas and two external antennas, and also supports manual angle adjustments for the two external antennas to achieve better video transmission effects.
Does DJI Mini 4 Pro support manual mode for shooting photos and videos?
Yes. You can manually set camera parameters like shutter speed, ISO, and white balance in the DJI Fly app.
What is the wind speed resistance of DJI Mini 4 Pro?
The max wind speed resistance of DJI Mini 4 Pro is 10.7 m/s.
Wind resistance is dependent upon propulsion. In strong winds, slight vibration is expected due to the drone’s lightweight nature. High-powered propulsion ensures the drone hovers stably or returns to home safely. DJI Mini 4 Pro automatically controls the gimbal to adjust slightly to ensure the footage is always stable and not affected by the wind.
1. The actual product weight may vary due to differences in batch materials and external factors. Registration is not required in some countries and regions. With the Intelligent Flight Battery Plus, the aircraft will weigh more than 249 g. Always check local laws and regulations before use.
2. Measured at a constant speed of 21.6 kph in windless conditions. The Intelligent Flight Battery Plus is not sold in Europe. Do not use it in Europe. Always check and strictly abide by local laws and regulations before flying.
3. Measured in an outdoor, open environment, without interference, and with FCC compliance. The above data shows the farthest communication range for one-way, non-return flights. Always pay attention to RTH reminders in the DJI Fly app during your flight.
