DJI Neo Intelligent Flight Battery
Related Products
It provides 18-minute flight time [1] to allow the drone to perform at least 20 palm takeoff and landing for excursions in succession. [2] Its lightweight design does not compromise battery life. Carry a few extra batteries to ensure you never miss a moment.
DJI Neo Intelligent Flight Battery × 1
Capacity: 1435 mAh
Weight: Approx. 45 g
Nominal Voltage: 7.3 V
Max Charging Voltage: 8.6 V
Battery Type: Li-ion
Energy: 10.5 Wh
Charging Temperature: 5° to 40° C
1. Measured in a controlled environment. Specific test conditions are as follows: flying forward at a constant speed of 2 m/s in a windless laboratory environment at 20 meters above sea level, in photo mode (without photo-taking operation during flight), and from 100% battery level until 0%. Results may vary depending on the environment, actual use, and firmware version.
2. Measured after DJI Neo is activated, with a fully charged battery and default settings, and using Circle, Rocket, and Dronie modes, and is for reference only.
