Designed for iPhone users, this mount snaps directly onto your phone's back via MagSafe, allowing you to skip the phone clamp for a more streamlined creative process.
Tips
1. Only supports iPhone 12 and later models; compatible with Apple's official iPhone cases with MagSafe, allowing for easy use without removing the case.
2. This accessory contains magnets. Keep it away from magnetic cards, IC cards, pacemakers, hard disks, RAM chips, and other objects that are subject to interference.
3. Before using wireless charging, remove the magnetic quick-release mount from the phone.
4. During use, make sure the magnetic quick-release mount is properly aligned with your phone's MagSafe magnet.
5. It is recommended to use the magnetic quick-release mount when the gimbal is stationary or moving slowly to keep your phone stable. Avoid using it during intense activities, rapid movements, or running to prevent the phone from falling.
6. When using the magnetic quick-release mount, the DJI OM 7 Series Tracking Kit is not compatible.
DJI OM Magnetic Quick-Release Mount × 1
Weight: Approx. 45 g
Osmo Mobile 7P
Osmo Mobile 7
Osmo Mobile 6
Osmo Mobile SE
DJI OM 5
DJI OM 4 SE
DJI OM 4
