bannerimg
Deliver to
Estimated shipping date: Apr. 1, expected arrival date: Apr. 4
USD $899USD $1,169
DJI Power 1000
  • 2048Wh High Capacity, 23.5L Compact Size
    DJI Power Expansion Battery 2000 offers a 2048Wh capacity, yet its size is comparable to the 1024Wh DJI Power 1000, making it easy to stack and carry.
  • Five Flexible Expansion Options
    The expansion battery can be connected to a Power 1000 unit [1] and up to five expansion batteries, offering five flexible expansion options: 3072 Wh, 5120 Wh, 7168 Wh, 9216 Wh, and 11264 Wh. [2]
  • 2400W Continuous Output
    When used with a Power 1000, the expansion battery can provide a continuous power supply of 2400 W [3] and a max output of 2600 W for 60 seconds. [4] The ultra-high output power can effortlessly power 99% of daily appliances. [5]
  • Ports On One Side, Easy to Stack and Store
    The ports, buttons, and screen are all integrated on the front of the unit. Both sides and the back of the unit have 1/4" threaded holes, making it more convenient to operate and secure the device.
  • Safe and Durable
    Allows for 4000 charge cycles. [7] DJI's intelligent Battery Management System adopts a new sub-nano protective coating technology, allowing the expansion battery to operate safely in conditions such as rain, condensation and salt spary. [8]
  • High-Power Recharging, 1024 Wh in 46 Mins
    When paired with a Power 1000, the expansion battery's recharging power can reach 1500 W, reaching 1024 Wh in approximately 46 minutes [6] for fast power when you need it urgently.
  • DJI Power Expansion Battery 2000
  • DJI Power Expansion Battery 2000 Cable
* If you already own a DJI Power 1000, you need to use the DJI Assistant 2 app to update the firmware of the power station to the latest version via a wired connection before using the expansion battery for the first time.
1. Sold separately.
2. DJI Power 1000 can connect up to 5 expansion batteries, which provide up to 11264 Wh when fully charged.
3. At an ambient temperature of 25° C, when used with DJI Power 1000 (DYM1000H, the 220V version), it can stably output at a maximum continuous power of 2400 W until battery runs out. Data was tested in a controlled laboratory environment.
4. Measured with the battery temperature at approx. 25° C and at approx. 50% battery level. Duration may vary due to differences in battery temperature and battery level. Refer to the actual usage. It is recommended to use the max power output when the battery is at a moderate temperature and a relatively higher battery level. Data was tested in a controlled laboratory environment.
5. When used with DJI Power 1000 (DYM1000H, the 220V version), it can support devices with power consumption not exceeding 2600 W.
6. Measured at an ambient temperature of 25° C with one expansion battery connected to DJI Power 1000 (via SDC to SDC) and being recharged by grid power at 1500 W (US)/1950 W (other regions) via the AC port on the power station. This data is for reference only. Actual user experience may vary.
7. Measured at an ambient temperature of 25° C when connected to the DJI Power 1000 and being recharged at 500 W and at 1000W output power. It maintains over 80% capacity after 4000 cycles. This data is for reference only. Actual user experience may vary.
8. To ensure product performance, it is not recommended to operate the expansion battery in a rainy environment for more than 3 minutes, or expose the expansion battery to condensation or salt fog for extended periods.
We Value Your Privacy
Cookie Preferences
