DJI RC Pro
- 15 km Video Transmission
- 120 ms Ultra-Low Latency
- 5.5-inch 1080p High-Bright Display
- Brightness Up to 1000 nits
- 3-hour Max Operating Time
Incredible Signal Range and Quality
The upgraded O3+ system supports a video transmission range of up to 15 km [1] with a latency as low as 120 ms.
High-Bright Screen
DJI RC Pro's 5.5-inch 1080p screen with a brightness of up to 1000 nits is perfect for Outdoor mode. Shadow details are enhanced for a clear display, even under direct sunlight.
Updated Processor for Upgraded Performance
DJI RC Pro is equipped with the latest-generation processor to bring a more durable, stable, and smooth system that simply enhances flying.
Fine-Tuned Control
DJI RC Pro uses the same control stick design as DJI FPV for precise maneuvering, fluid operation, and better shot composition.
Outstanding Audio and Video Functions
DJI RC Pro supports videos played at 4K/120fps in H.264 and H.265 codecs. The system supports the installation of third-party apps [2] for more diversified editing and sharing options.
DJI RC Pro
USB 3.0 Type-C Cable
Compared with the DJI Smart Controller, what major upgrades does DJI RC Pro have?
Featuring a next-generation processor, DJI RC Pro is the newest high-performance remote controller platform with a built-in screen. Compared with the DJI Smart Controller, the performance of the CPU and GPU of DJI RC Pro is increased by 4 times and 7 times respectively, with boosted system performance and lower power consumption, offering longer use duration and a smoother control experience. DJI RC Pro also features a comprehensively improved transmission system. It supports the brand-new O3+ transmission with a livestreaming at up to 1080p/60fps and a max transmission range of 15 km. In addition, DJI RC Pro adopts the same control sticks of DJI FPV for more precise, responsive, and smooth operation.
What are the differences between the ultra-bright display of DJI RC Pro and a normal display?
DJI RC Pro provides brightness up to 1000 nits, showing clear details even under direct sunlight, making it an optimal tool for outdoor use. Normal phone screens, however, cannot provide a constant high level of brightness and will automatically decrease brightness in an outdoor environment.
Does DJI RC Pro support quick charging?
Yes, it supports mainstream quick-charging solutions. It takes 2 hours to fully charge DJI RC Pro with a 12V charger, and 1.5 hours with a 15V charger.
What is the operating time of DJI RC Pro?
3 hours or longer under normal operating conditions.
Does DJI RC Pro have a speaker and microphone?
DJI RC Pro has a built-in speaker, but does not have microphone. For phone calls and recording, it supports an external microphone through the USB Type-C port.
*Tested with a DJI Mavic 3 production model in a closed environment in favorable conditions and with an unobstructed wireless signal. Actual results may vary depending on the environment, usage, and firmware version.
**All videos and photos on this page were taken in strict compliance with local laws and regulations.
1. Unobstructed, free of interference, and when FCC-compliant. Maximum flight range specification is a proxy for radio link strength and resilience. Always follow local rules and regulations and fly your drone within your visual line of sight unless otherwise permitted.
2. DJI is not responsible for permissions or information security related to third party apps, and does not provide any technical support for compatibility issues with third party applications. If an installed third-party app prevents you from enjoying optimal use of your controller, we suggest you remove the app or restore the controller to the original factory settings.
