DJI RS 4
  • 2nd-Gen Native Vertical Shooting
    The newly designed gimbal horizontal plate eliminates the need for additional accessories. Easily switch to vertical shooting [1] for efficient vertical video creation.
  • Joystick Mode Switch for Zoom/Gimbal Control
    Cinematographers can easily toggle between joystick modes, allowing them to control either the gimbal movement or the lens zoom via the joystick for a native zoom experience. [2]
  • RSA Communication Port for Extensive Control Ecosystem
    DJI RS 4 introduces an RSA communication port, which allows for the connection of accessories such as the DJI RS Tethered Control Handle and third-party accessories. [3]
  • High-Capacity Battery Grip for Approx. 2.5x Battery Runtime [4]
    The new BG70 High-Capacity Battery Grip [3] can extend RS 4's battery runtime to 29.5 hours. [5] It also supports powering camera and accessories with up to 18 W via the USB-C port.
  • Teflon™-Coated Axis Arms for Smoother Balancing
    Reduced friction aids in smoother balancing and a fine-tuning knob on the tilt axis moves the camera forward and backward for precise, millimeter-level balancing.
  • 3kg (6.6lbs) Payload Capacity With Extended Tilt Axis
    In addition to a high-payload capacity, the tilt axis has been extended by 8.5 mm, allowing for mainstream mirrorless camera and lens combinations, and additional accessories.
  • Gimbal
    Gimbal
  • BG21 Battery Grip
    BG21 Battery Grip
  • Quick-Release Plate (Arca-Swiss/Manfrotto)
  • Extended Grip/Tripod (Plastic)
  • Lens-Fastening Support
  • Multi-Camera Control Cable (USB-C, 30 cm)
    × 2
  • Screw Kit
    Screw Kit
  • DJI Logo Sticker
    DJI Logo Sticker
  • Briefcase Handle
    Briefcase Handle
  • Carrying Case
    Carrying Case
  • Focus Pro Motor
    Focus Pro Motor
  • Focus Pro Motor Rod Mount Kit
  • FIZ Sticker
    FIZ Sticker
  • Focus Gear Strip
    Focus Gear Strip
  • DJI SDR Transmission Transmitter (TX)
  • DJI SDR Transmission Receiver (RX)
  • USB-A to USB-C Cable (43 cm)
  • TX Camera Mounting Adapter Plate
  • TX Gimbal Mounting Adapter Plate
DJI RS 4 Mini
DJI RS 3 Mini
DJI RS 4
DJI RS 4 Pro
DJI RS 4 Mini
DJI RS 3 Mini
DJI RS 4
DJI RS 4 Pro
DJI RS 4 Mini
DJI RS 3 Mini
DJI RS 4
DJI RS 4 Pro
Lightweight Travel Camera Stabilizer
Expansive Flagship Stabilizer
From €399
From €259
From €479
From €879
890 g (2 lbs)Gimbal Weight
795 gWeight
1.4 kg (3.1 lbs)Gimbal Weight
1.6 kg (3.5 lbs)Gimbal Weight
2 kg (4.4 lbs)Max Payload
3 kg (6.6 lbs)Max Payload
4.5 kg (10 lbs)Max Payload
2nd-Gen AutomatedAxis Locks
Manual Axis LocksAxis Locks
2nd-Gen Automated Axis LocksAxis Locks
Aluminum AlloyAxis Arm Material
Carbon FiberAxis Arm Material
YesFine-Tuning Knob
YesFine-Tuning Knob
YesFine-Tuning Knob
img1.4″ LCD Full-Color
img1.4″ LCD Full-Color Touchscreen
img1.8″ OLED Full-Color Touchscreen
img4th-Gen Stabilization Algorithm
img3rd-Gen RS Stabilization Algorithm
img4th-Gen RS Stabilization Algorithm
Zoom/Gimbal ControlJoystick Mode
img3rd-Gen Native Vertical Shooting
imgNative Vertical Shooting (Horizontal Arm Detachment Required)
img2nd-Gen Native Vertical Shooting
Non-DetachableBattery Design
UndetachableBattery Design
13 Hours‌Max Battery Runtime
10 Hours‌Max Battery Runtime
29.5 Hours‌Max Battery Runtime
29 Hours‌Max Battery Runtime
imgNATO Port × 1
imgNATO Port × 1
imgRSA Port × 1;
NATO Port × 2;
Charging Adapter Port × 1
imgRSA Port × 2;
NATO Port × 2;
imgSupports Bluetooth zoom control, Bluetooth shutter and wired shutter
imgSupports Bluetooth shutter and wired shutter
imgSupports external focus motor control, Bluetooth zoom control, Bluetooth shutter, and wired shutter
imgSupports dual external focus motor control, Bluetooth zoom control, Bluetooth shutter, and wired shutter
imgDJI PRO Ecosystem
Camera Compatibility List
1. The gimbal requires rebalancing after switching between horizontal and vertical shooting.
2. For more details on camera and lens compatibility, please refer to the Ronin Series Compatibility Search page.
3. Sold separately.
4. Data was measured by comparing the battery runtime of DJI RS 4 equipped with the DJI RS BG70 High-Capacity Battery Grip and that of DJI RS 4 equipped with the DJI RS BG21 Battery Grip. Battery runtime was measured in a 25° C (77° F) indoor environment with the gimbal balanced in a level and stationary state until the battery level reached 3% (with the battery grip only powering the gimbal).
5. Measured in a 25° C (77° F) indoor environment with the gimbal balanced in a level and stationary state until the battery level reached 3% (with the battery grip only powering the gimbal).
6. The DJI RS 4 Combo includes a DJI Focus Pro Motor. For the standalone version, the motor is sold separately.
