Inspire 1 V2.0 Everything You Need Kit
DJI CARE
"The DJI Inspire 1 is a well-built, ready-to-fly quadcopter that captures excellent 4K-resolution video."
- CNET, August 23, 2015
"DJI Inspire 1: A Badass Drone That Shoots Lovely 4K Video." - GIZMODO, November 12, 2014
"The DJI Inspire One is the coolest drone I've ever seen." - THE VERGE, November 12, 2014
ADVANCED, READY-TO-FLY DESIGN
Imagine holding the future in your hands. Designed to be powerful while lightweight, flexible while providing the stability you need, the Inspire 1 is DJI’s most advanced complete package. All of the latest aerial technology is packed into one simple, ready-to-fly system, putting you in the sky within minutes.
POWERFUL PROPULSION SYSTEM
The Inspire 1’s propulsion system is unique among all flight platforms. We re-engineered and re-built the system to handle the demands of advanced flight, while increasing efficiency and reliability.
AERODYNAMIC TRANSFORMING DESIGN
Carbon fiber arms give you the strength to maneuver in the air and they transform, moving out of the camera’s way at the flick of a switch. With a full 360⁰ unobstructed view, you now have the freedom to capture shots independent of the direction you are flying.
Every part, every component of the Inspire 1 was engineered to be durable and lightweight. The body’s aerodynamic design cuts through the sky and further enhances your control over the aircraft. This ensures long flight times and a long operational life.
MODULAR, UPGRADEABLE SYSTEM
Inspire 1’s gimbal and camera system can be removed from the aircraft for safe transport and future upgrades.
NEW CAMERA AND GIMBAL SYSTEM
Get crystal clear images with DJI’s most advanced camera to date. The gimbal holding your camera is the result of DJI’s years of expertise in camera stabilization, giving you smooth, stable footage in any flight conditions.
LIVE HD VIEW
A beautiful, 720p HD view shows you exactly what your camera sees at all times. Frame your shots and fly as though you‘re in the sky yourself.
This is made possible by an all new and improved version of DJI’s Lightbridge technology which can transmit video from up to 5km away.
CREATE TOGETHER
For an even greater level of precision, use a second remote controller and fly with a friend. With two operators controlling the same Inspire 1, one person pilots the flight path while the other aims the gimbal and camera.
Each user can have their own screen to see exactly what is being shot in real-time. By working in tandem, you’re capturing shots that are more complex and artistic than ever before.
FLY INDOORS AND WITHOUT GPS USING VISION POSITIONING SYSTEM
Indoor flight has always been a true test of skill for all levels of pilots. DJI’s new Vision Positioning technology uses a specially designed camera as well as sonic waves to bring simplicity to flying indoors. This technology allows the Inspire to hold its position, stop when the controls are released, and respond to your commands even when GPS is unavailable.
INTELLIGENT POWER MANAGEMENT SYSTEM
A fully integrated intelligent battery powers your Inspire 1 and virtually manages itself.
When in flight, your remaining battery power is shown live, letting you know how long you can continue to fly. Advanced algorithms calculate the distance of your aircraft and estimated time to return home, letting you know when it’s time to fly back.
The battery reports the voltage of each cell, the total lifetime charges and discharges, and the overall health and battery status. All this helps you keep your Inspire 1 in the air and flying for years to come.
POWERFUL MOBILE APP
Complete power is at your fingertips. Control the camera and change flight settings, all from your mobile device. Plus:
DEDICATED CONTROLS
Take absolute control of your Inspire 1 with DJI’s most sophisticated remote controller to date. Featuring dedicated buttons
for photo and video capture, a gimbal control dial, an integrated rechargeable battery and more, it’s easy and intuitive to fly.
The controller has an mini-HDMI and USB port allowing you to connect mobile devices or compatible screens.
EASY, SAFE FLIGHT
Even if you’ve never flown before, taking off and landing your Inspire 1 is easy and safe. It takes just one tap to make your Inspire 1 takeoff and transform, ready to start filming. Then tap again to have it transform into landing mode and land.
When GPS is available, the Home Point (the location you are standing) automatically refreshes, so your Inspire 1 always knows where you are even if you move around. When you tell it to come back, or in case of an emergency, it knows exactly where to go and land safely.
A COMPLETE READY-TO-FLY SYSTEM
Everything you need is included and ready to go, offering you a complete aerial filmmaking tool in one box. Just add your mobile device or other screen to use the live HD view.
Are the two remote controllers the same? Should I setup the remote controllers in the app or somewhere else to control the camera and aircraft separately?
The two remote controllers are physically identical. You can set the remote controllers to either "Master" or "Slave" through the DJI GO app if you wish to use dual controller mode.
Can I upgrade and buy a second remote controller if I only buy a single remote controller now?
Yes.
How big is the Inspire 1?
Its length x height x width dimensions without the propellers attached are 44 x 30 x 45cm (17.3 x 11.8 x 17.7in).
What flight controller does the Inspire 1 use?
The Inspire 1 uses its own new flight controller.
Which motors and propellers does the Inspire 1 come with?
The Inspire 1 uses 3510H motors and 1345T propellers.
Does the Inspire 1 have a SD card included?
The Inspire 1 comes with a 16GB micro-SD card. It supports SD cards up to 64GB.
How can I put a GoPro camera on the Inspire 1?
The Inspire 1 does not currently support GoPro attachments. The gimbal is designed to hold DJI cameras only.
Is the camera's exposure automatic?
The exposure can be set to Auto, for automatic changes, or Manual, if you wish to use a specific setting.
How much weight can the Inspire 1 carry without its included camera?
We do not recommend flying with any payload other than the included DJI gimbal and camera.
Can I see the size of images through the app?
Yes, you can preview image or video sizes through the DJI GO app.
Do you have an LCD monitor available for the Inspire 1?
No, DJI does not sell LCD or HD monitors for the Inspire 1. However, you can output the live streaming video to a compatible monitor or mobile device of your own.
How long does it take to charge the battery? Does it comes with a charger?
Yes, all Inspire 1 units come with standard TB47 charger.
With the standard TB47 100W charger, it takes 85min to fully charge a 4500mAh battery.
Can the mobile device holder be used on the Phantom 2 series remote controller?
No, it cannot. The mobile device holder can only be used with the Inspire 1 remote.
Where can I find info on the simulation application that plugs into the trainer port? Can you suggest a simulation program?
There is no trainer port on the remote controller for the Inspire 1.
When will ground station functionality be available?
The Inspire 1 does not currently support ground station.
