DJI Battery Station
Related Products
Out of stock
The DJI Battery Station is efficient and intelligent for charging to get shooting started immediately. It can charge up to eight TB50 Intelligent Batteries simultaneously, and can also charge the WB37 Battery Charging Hub. There is also a USB port to supply power for a mobile device. Overall, the DJI Battery Station is a one-stop power station for a wide variety of essential devices.
Super large storage space for up to 12 TB50 Intelligent Batteries, two WB37 Batteries, and one WB37 Battery Charging Hub.
Multiple ports let you charge up to eight TB50 batteries simultaneously, and supply power for an Inspire 2 remote controller, WB37 Battery, and a mobile device.
When charging a TB50 Intelligent Battery, the Battery Station's LCD screen displays its current firmware version.
Quick, simple, and intelligent discharging feature improves battery maintenance for storage and travel.
A built-in cooling fan ensures every battery stays within a safe range. The Battery Station automatically cancels charging and discharging to avoid any safety hazards when overheating is detected.
Wheels and a telescopic handle make the Battery Station convenient for travel.
Battery Station × 1
AC Power Cable × 1
Remote Controller Charging Cable × 2
Model: IN2BS
Dimensions (mm): 484×226.5×220
Net Weight: 7.7 kg
Max Internal Load: 12 kg
Compatible Stored Items:
TB50 Intelligent Battery × 12
WB37 Battery × 2
WB37 Battery Charging Hub × 1
AC Power Cable × 1
Input: 100-240 V, 50-60 Hz
Output:
Battery Port: 26.1 V max., 6.75 A max. × 8
Remote Controller Port: 26.1 V max., 4 A max. × 2
USB Port: 5 V, 2 A × 2
Operating Temperature Range: 41° to 104° F (5° to 40° C)
Charging Time*:
TB50 Intelligent Battery:
90 minutes (Normal mode); 35 minutes (Quick mode); 4 hrs 20 minutes (Silent mode)
Remote Controller:
2 hrs 24 minutes (GL6D10A); 3 hrs (GL800A)
*Charging times tested in a lab environment at room temperature (25° C). Results should be used for reference only.
DJI Ronin 4D
Inspire 2 TB50 Intelligent Flight Battery
WB37 Battery
Inspire 2 Remote Controller
Ronin 2 Remote Controller
Matrice 200 Remote Controller
Smart Mobile Device
Ronin 2 TB50 Intelligent Battery
