Mavic Air 2 Protector Case
The Mavic Air 2 Protector Case offers both protection and excellent storage ability.
The case is IP67-rated and resistant to impact when dropped from a height of one meter. Passing rigorous tests of high and low temperatures, as well as a vibration test, the Mavic Air 2 Protector Case will protect your aircraft through adverse conditions and harsh weather environments.
It will ensure that the contents of the case are kept safe and dry during transportation.The interior of the box is carefully designed to fit your Mavic Air 2 or DJI Air 2S with foam inserts that provide an exact fit for your gear while keeping it safe from impact. Ample interior space accommodates the aircraft and remote controller, as well as five spare batteries, power adapter, car charger, battery charging hub, power cable, battery to power bank adapter, ND filter set, and two pairs of spare propellers.
IP67 Rated
High-quality protection and comprehensive storage
Protector Case × 1
Box size: 359 × 308 × 175 mm
Weight: 1850 g
DJI Air 2S
Mavic Air 2
