DJI Mini 2
  • 4x Digital Zoom
    Safer and more convenient when transitioning between shots of varying distance and composition.
  • QuickTransfer
    Download footage at a high speed without the remote controller.
  • OcuSync 2.0
    Fly farther and see clearer with up to 10 km of HD video transmission. *
  • Level 5 Wind Resistance (29-38 kph)
    Stable footage in even more locations and conditions.
  • Small But Mighty
    At less than 249 g, the camera supports 4K/30fps video, making it your ideal travel companion. [1]
  • Aircraft
    Aircraft
  • Remote Controller
    Remote Controller
  • Intelligent Flight Battery
  • Pair of Spare Propellers
  • Gimbal Protector
    Gimbal Protector
  • USB-C Data Cable
    USB-C Data Cable
  • RC Cable (USB Type-C Connector)
  • RC Cable (Lightning Connector)
  • RC Cable (Standard Micro-USB Connector)
  • Pair of Spare Control Sticks
  • Spare Screw
    Spare Screw
    × 6
  • Screwdriver
    Screwdriver
Moments by You
DJI Mini 2
DJI Mini 3
DJI Mini 2
DJI Mini 3 (DJI RC-N1)
DJI Mini 2
DJI Mini 3
Entry-Level
Entry-Level
Lightweight and Easy-To-Use Camera Drone
Premier Entry-Level Camera Drone
From 459 €
From 318 €
Highlights
< 249 gWeight
< 249 gWeight
31 minsMax Flight Time
38 minsMax Flight Time
imgTrue Vertical Shooting
Image Quality
img1/2.3'' CMOS
img1/1.3″ CMOS
12 MPPixels
48 MPMax Pixels
4K4K/30fps
4K4K/30fps HDR
Safety & Flight Performance
imgDownward Vision System
imgDownward Obstacle Sensing
imgDJI O2 10km,
720p/30fps Transmission
imgMax Video Transmission Range: 10 km (FCC)
6 km (CE/SRRC/MIC)
imgMax Takeoff Altitude
1. Aircraft takeoff weight includes battery, propellers, and a microSD card. Check all applicable rules and regulations before use and always fly safely near others.
** Vision positioning requires non-reflective, discernable surfaces, and adequate lighting. Available at altitudes from 0.5-30 m. The vertical and horizontal positioning accuracy is within ±0.1 m.
*** Omnidirectional Obstacle Sensing includes left/right, up/down, and forward/backward obstacle sensing. Sensing for left/right directions is only available in ActiveTrack , POI, QuickShot, and Tripod modes. Omnidirectional Obstacle Sensing does not fully cover the circumference of a 360-degree arc. And left and right obstacle sensing system only works in specific modes and environments. DJI warranty does not cover any loss caused by crashing when flying left or right, even when ActiveTrack or Tripod mode is activated. Please be aware of your surroundings and App notifications when operating the Mavic 2 to ensure safety.
