When used with Osmo 360, the selfie stick disappears from the shot, enabling a dramatic third-person perspective *; it extends up to 1.2 meters, offering a wider field of view. Equipped with an adjustable quick-release adapter mount, it supports fast angle adjustments, achieving either the invisible selfie stick effect or precise single-lens framing.
* Recommended for handheld use only. Do not use in environments with strong vibrations. For vehicle-mounted applications (e.g., motorcycles or cars), use the High-Strength Carbon Fiber Invisible Selfie Stick together with the appropriate stabilizing accessories.
Tips
Before storing the selfie stick, ensure that sand and other foreign objects are removed from the surface. If the selfie stick comes into contact with seawater, rinse it with fresh water and dry it thoroughly before storing.
Osmo 1.2m Invisible Selfie Stick × 1
Osmo Adjustable Quick-Release Adapter Mount × 1
Dimensions (Folded): Length approx. 251 mm, diameter approx. 24 mm
Dimensions (Unfolded): Length approx. 1200 mm, diameter approx. 24 mm
Weight: Approx. 137 g
Dimensions: Approx. 41 × 22 × 32 mm (L × W × H)
Weight: Approx. 27 g
Osmo Nano
Osmo 360
